After I downloaded the GuruxDLMSLibServerExample.zip from http://www.gurux.fi//OwnDLMSDevice, I tried to build it in Visual Studio 2010 but failed. May I know which VC version is recommended?
Sincerely thanks and looking forward to your guidance.
Following are the warning and error info FYI:
1>InitializeBuildStatus:
1> Creating “Debug\GuruxDLMSLibServerExample.unsuccessfulbuild”
1>ClCompile:
1> Deleting “Debug\GuruxDLMSLibServerExample.pch”。
1> stdafx.cpp
1> GXNet.cpp
1> GXDLMSBase.cpp
1> GuruxDLMSLibServerExample.cpp
1> Generating...
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : warning LNK4049: Imported local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@PBD@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : warning LNK4217: Local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@PBD@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXObject.obj) : warning LNK4049: Imported local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@PBD@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4049: Imported local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@PBD@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMS.obj) : warning LNK4049: Imported local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@PBD@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : warning LNK4049: Imported local defined symbol ??1?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@XZ (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : warning LNK4217: Local defined symbol ??1?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@XZ (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXObject.obj) : warning LNK4049: Imported local defined symbol ??1?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@XZ (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4049: Imported local defined symbol ??1?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@XZ (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMS.obj) : warning LNK4049: Imported local defined symbol ??1?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@XZ (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : warning LNK4217: Local defined symbol ??4?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV01@ABV01@@Z (public: class std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4217: Local defined symbol ??4?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV01@ABV01@@Z (public: class std::basic_string
1>GuruxDLMSLib.lib(GXDLMS.obj) : warning LNK4049: Imported local defined symbol ??4?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV01@ABV01@@Z (public: class std::basic_string
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : warning LNK4217: Local defined symbol ??4?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV01@ABV01@@Z (public: class std::basic_string
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : warning LNK4049: Imported local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@ABV01@@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : warning LNK4217: Local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@ABV01@@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXObject.obj) : warning LNK4049: Imported local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@ABV01@@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4049: Imported local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@ABV01@@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMS.obj) : warning LNK4049: Imported local defined symbol ??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@ABV01@@Z (public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : warning LNK4049: Imported local defined symbol ?c_str@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEPBDXZ (public: char const * __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : warning LNK4217: Local defined symbol ?c_str@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEPBDXZ (public: char const * __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXObject.obj) : warning LNK4049: Imported local defined symbol ?c_str@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEPBDXZ (public: char const * __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4049: Imported local defined symbol ?c_str@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEPBDXZ (public: char const * __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMS.obj) : warning LNK4049: Imported local defined symbol ?c_str@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEPBDXZ (public: char const * __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : warning LNK4217: Local defined symbol ?append@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV12@PBD@Z (public: class std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4049: Imported local defined symbol ?append@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV12@PBD@Z (public: class std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : warning LNK4217: Local defined symbol ?begin@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE?AV?$_String_iterator@DU?$char_traits@D@std@@V?$allocator@D@2@@2@XZ (public: class std::_String_iterator
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : warning LNK4217: Local defined symbol ?end@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE?AV?$_String_iterator@DU?$char_traits@D@std@@V?$allocator@D@2@@2@XZ (public: class std::_String_iterator
1>GuruxDLMSLib.lib(GXObject.obj) : warning LNK4217: Local defined symbol ?size@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEIXZ (public: unsigned int __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4217: Local defined symbol ?size@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEIXZ (public: unsigned int __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMS.obj) : warning LNK4049: Imported local defined symbol ?size@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEIXZ (public: unsigned int __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : warning LNK4217: Local defined symbol ?size@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEIXZ (public: unsigned int __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4217: Local defined symbol ??A?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAADI@Z (public: char & __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : warning LNK4049: Imported local defined symbol ??A?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAADI@Z (public: char & __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4217: Local defined symbol ?length@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBEIXZ (public: unsigned int __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4217: Local defined symbol ??4?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV01@PBD@Z (public: class std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4217: Local defined symbol ?clear@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEXXZ (public: void __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : warning LNK4217: Local defined symbol ?append@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV12@ABV12@@Z (public: class std::basic_string
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : warning LNK4217: Local defined symbol ?append@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV12@PBDI@Z (public: class std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __thiscall std::_Container_base_secure::_Orphan_all(void)const " (__imp_?_Orphan_all@_Container_base_secure@std@@QBEXXZ)
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __thiscall std::_Container_base_secure::_Orphan_all(void)const " (__imp_?_Orphan_all@_Container_base_secure@std@@QBEXXZ),the symbol was referenced in "public: class std::vector
1>GuruxDLMSLib.lib(GXObject.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __thiscall std::_Container_base_secure::_Orphan_all(void)const " (__imp_?_Orphan_all@_Container_base_secure@std@@QBEXXZ)
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __thiscall std::_Container_base_secure::_Orphan_all(void)const " (__imp_?_Orphan_all@_Container_base_secure@std@@QBEXXZ)
1>GuruxDLMSLib.lib(GXDLMS.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: void __thiscall std::_Container_base_secure::_Orphan_all(void)const " (__imp_?_Orphan_all@_Container_base_secure@std@@QBEXXZ)
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_String_base::~_String_base(void)" (__imp_??1_String_base@std@@QAE@XZ),the symbol was referenced in "public: __thiscall std::_String_val
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::~_Container_base_secure(void)" (__imp_??1_Container_base_secure@std@@QAE@XZ),the symbol was referenced in "class CGXDLMSVariant * __cdecl stdext::unchecked_copy
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::~_Container_base_secure(void)" (__imp_??1_Container_base_secure@std@@QAE@XZ)
1>GuruxDLMSLib.lib(GXObject.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::~_Container_base_secure(void)" (__imp_??1_Container_base_secure@std@@QAE@XZ)
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::~_Container_base_secure(void)" (__imp_??1_Container_base_secure@std@@QAE@XZ)
1>GuruxDLMSLib.lib(GXDLMS.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::~_Container_base_secure(void)" (__imp_??1_Container_base_secure@std@@QAE@XZ)
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_String_base::_String_base(void)" (__imp_??0_String_base@std@@QAE@XZ),the symbol was referenced in "protected: __thiscall std::_String_val
1>GuruxDLMSLib.lib(GXOBISTemplate.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::_Container_base_secure(void)" (__imp_??0_Container_base_secure@std@@QAE@XZ)
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::_Container_base_secure(void)" (__imp_??0_Container_base_secure@std@@QAE@XZ),the symbol was referenced in "protected: __thiscall std::_Container_base_aux_alloc_empty
1>GuruxDLMSLib.lib(GXObject.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::_Container_base_secure(void)" (__imp_??0_Container_base_secure@std@@QAE@XZ)
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::_Container_base_secure(void)" (__imp_??0_Container_base_secure@std@@QAE@XZ)
1>GuruxDLMSLib.lib(GXDLMS.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __thiscall std::_Container_base_secure::_Container_base_secure(void)" (__imp_??0_Container_base_secure@std@@QAE@XZ)
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: static void __cdecl std::_String_base::_Xran(void)" (__imp_?_Xran@_String_base@std@@SAXXZ),the symbol was referenced in "public: class std::basic_string
1>GuruxDLMSLib.lib(GXDLMSServerBase.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: static void __cdecl std::_String_base::_Xlen(void)" (__imp_?_Xlen@_String_base@std@@SAXXZ),the symbol was referenced in "protected: bool __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: int __thiscall std::basic_string
1>GuruxDLMSLib.lib(GXDLMSVariant.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: class std::basic_string
1>GuruxDLMSLib.lib(GXDLMS.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __thiscall std::_Container_base_secure::_Swap_aux(class std::_Container_base_secure &)" (__imp_?_Swap_aux@_Container_base_secure@std@@QAEXAAV12@@Z),the symbol was referenced in "public: void __thiscall std::vector
1>GuruxDLMSLib.lib(GXDLMS.obj) : error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __thiscall std::_Container_base_secure::_Swap_all(class std::_Container_base_secure &)const " (__imp_?_Swap_all@_Container_base_secure@std@@QBEXAAV12@@Z),the symbol was referenced in "public: void __thiscall std::vector
1>C:\Gurux\GuruxDLMSLibServerExample\Debug\GuruxDLMSLibServerExample.exe : fatal error LNK1120: 14 unresolved external command
1>
1>Generation failed.
1>
May I know the VC version of the GuruxDLMSLibServerExample ?
We are using 2008. We will check this with 2010 ASAP.
We have updated the example. Now VS 2010 is also supported. Make sure that you link right lib or you get errrors.
Libraries are:
GuruxDLMSLib_2008.lib for VS 2008
GuruxDLMSLib_2010.lib for VS 2010.
GuruxDLMSLib_2010.lib where to get?
From where can I get the library GuruxDLMSLib_2010.lib please let me know.
New version is updated. You can download it.
http://www.gurux.org/files/GuruxDLMSLibServerExample.zip
