By suteme, 25 March, 2010
Hi!
I received a message telling about a problem with an installer of GXPing and Vista. I answered to the question directly by E-mail, of course, but came to think that the user asking about it, may not be the only one with the problem. That is why I now add the issue here, so that the answer is available to you all.
The asker told us about getting an error when trying to install GXPing to Vista (32bit). The error said to contact the vendor, and to check if the installer was a valid Windows Installer package.
This got us thinking that maybe the version was 64bit, instead of 32bit, as it should have been. We have released both, and this may have caused the problem.
Personally, I don't understand, why a marking of "x86" is generally used for 32bit versions, as 64bit versions are marked with "x64".
Anyway, I hope this message helps, if anyone else if struggling with the same kind of problem!
MerjaS
Gurux Ltd Web Team
