  2. ISKRA ME372 CONNECTION BY DLMSDIRECTOR
By savas , 21 April, 2026
I USE YOUR SOFTWARE TO CONNECT ISKRA ME372 . I TRY DIFFERENT SETTINGS BUT ITS NOT CONNECT . YOU HAVE A DATA ABOUT CONNECT THIS METER WITH OPTICAL PORT
INTERFACE:
AUTHENTICATION:
PASSWORD:
ADRESS:
LOCAL SERVER:
CLIENT ADRESS
LOGICAL DEVICE:
BAUD RATE:
DATA BITS:
PARITY:
STOP BITS:
CAN YOU GIVE THESE PARAMETERS PLEASE .
3 months 3 weeks ago
Hi, If you are using an…
If you are using an optical port, select Iskra as a manufacturer and then change Interface from HDLC to HdldWithModeE.
  • negative indexing for custom method/attribute
  • System title
  • Elster a1800 clock reset to year 2000 with one tariff billing
