  2. Gurux Simulator
Gurux simulator
By NordicRelay, 26 January, 2026
I would like to ask whether the conformance tests are aligned with the latest Yellow Book or with any version of the Yellow Book. I have also launched the simulation model of an electric power meter and disabled all tests except the HDLC tests, but it still fails several of them. The results show: Test #1 failed, Test #2 failed, Test #4 failed, Test #10 failed, Test #14 failed, Test #15 failed, Test #16 failed, Test #17 failed, Test #18 failed, and Test #19 failed.
Could this be caused by glitches in the packet formation of the Gurux library, or am I doing something wrong?
4 days 5 hours ago
Hi, The simulator is a…
The simulator is a simple server designed to allow users to quickly generate DLMS meters. It is not intended to pass DLMS compliance tests.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
