  2. Online Vs Offline DLMS Translator
Online vs Offline DLMS translator
By Sief, 31 December, 2025
Hello All,
I was trying to parse an HDLC frame(not DLMS) using GXDLMS DLMS translator.
I found that the online version of the tool parses the frame in a different manner than the offline tool, specifically the HDLC payload.
The online version always deducts the first byte of the payload while the offline tool shows the whole payload as expected.
I'm using HDLC type format 3 which shows that the payload starts right after the 2-bytes Header Check Sum (HCS).
Is there a reason why the offline parsing mechanism differ than the online one ?
1 month 1 week ago
Hi, The new version from…
The new version from online tool is released in the following weeks, where this is fixed. GXDLMSDirector shows the data correctly.
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Landisgyr meter
  • GxDateTime always return DayOfWeek as FF
  • Python GXDLMSTranslator
