  2. The Client Instance Code Failed To Connect To The Electricity Meter For Authentication
The client instance code failed to connect to the electricity meter for authentication
By Jay zhai, 29 October, 2025
Hello, I'm currently encountering a situation where I'm using the official version of the.c client source code to read the electricity meter data, but the reading keeps failing.
The all-0 key I set when using the GXDLMSDirector client can be read normally,However, use https://github.com/Gurux/GuruxDLMS.c/tree/948da08617e623f5e3f6dd3dab9ad… appear error.
This is my execution order:
sudo ./bin/gurux.dlms.client.bin \ -S /dev/ttyUSB0 -c 32 -s 1 -r LN \ -a HighGmac -C Authentication \ -v 0.0.43.1.2.255 \ -T 484C592D474D4143 \ -A 00000000000000000000000000000000 \ -B 00000000000000000000000000000000 \ -t Verbose
The following is my error message:
RX: 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 C8 06 01 C8 07 04 00 00 00 01 08 04 00 00 00 01 AC B3 7E
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF E7 25 7E
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 12 1C 01 90 00 07 7E 7B 7E
TX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 02 FF 02 00 0B B6 7E
RX: 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 6B A8 C5 7E
Invocation counter: 108 (0x6C)
RX: 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 C8 06 01 C8 07 04 00 00 00 01 08 04 00 00 00 01 AC B3 7E InitializeConnection
TX: 7E A0 07 03 41 93 5A 64 7E
RX: 7E A0 1E 41 03 73 8E 7F 81 80 12 05 01 C8 06 01 C8 07 04 00 00 00 01 08 04 00 00 00 01 AC B3 7E
TX: 7E A0 6B 03 41 10 19 DC E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 4C 59 2D 47 4D 41 43 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 10 00 00 00 6C 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF 62 67 FD 5B 7D 9C 42 9E 7F C4 90 6A C8 7D 7E
RX: 7E A0 5A 41 03 30 4A 6B E6 E7 00 61 4C A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 A4 0A 04 08 48 4F 4C 00 0C EC 4F 83 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 0C 88 B5 41 7C 7D 2B DA CD D0 24 8A 4D 7A DE C3 BE 06 04 04 0E 01 06 02 A6 F0 7E
AARQRequest failed No reason given.
TX: 7E A0 07 03 41 53 56 A2 7E
No reason given.
I've tried methods like modifying counters,Please give me the right way
5 months 1 week ago
Hi, The meter returns…
The meter returns IncompatibleConformance. I don't know if that's the real error or if your block cipher key differs from the meter key.
Check your block cipher and authentication keys first. They MUST be the same as the meter is using.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
