  2. Metcom MCS301-C341C RS485
By zainimran@hedg…, 30 September, 2025
Good day
i Am in need of assistance to connect a Metcom MCS301-C341C to DLMS Director over RS485 i am using a RS485-USB converter to try and connect to the meter but have not had luck in getting a response from the meter please may you guide me through the settings
setting i have tried on the DLMS Director are attached below
Interface: HDLC
Authentication: Reader
Password: 12345678
Client Address: 4
Baud Rate: 9600
Data Bits: 8
Parity: NONE
Stop bits: One
Flow Control: None
Any guidance on how I could possibly test the connection and find a way of getting a response will be great
3 months 2 weeks ago
Hi, The problem is in the…
The problem is in the baud rate or in the server address. Can you connect to the meter with an optical probe or TCP/IP connection?
I'll have Metcom MCS301-CE41C, but I can't remember if this meter supports RS-485.
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • 6-digit field values from meter not fully received (only 5 digits shown)
  • Gurux DLMS Android App
