  2. LLS Secret Key Chnage
LLS secret key chnage
By SMETGURUX, 15 September, 2025
I connected with Association 48 HLS and tried to change LLS secret key. secret key change successfully but gives an error
Access error : Device reports scope of access violated
4 months ago
Hi, Can you connect with the…
Can you connect with the old or new LLS key, or is this error coming when you try to change the key?
SMETGURUX
4 months ago
after changing the secret…
after changing the secret key, it is connecting with new LLS key.
this error is comming during changing the secret key.
4 months ago
Hi, If the key is changed,…
If the key is changed, this is a meter issue. You should ask for the new firmware for the meter.
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • 6-digit field values from meter not fully received (only 5 digits shown)
  • Gurux DLMS Android App
