  2. Certificates In AARQ
Certificates in AARQ
By enemy235, 26 August, 2025
I want to ask, if sending a certificate in AARQ is supported in latest version (Java or .Net).
There is a year old topic about it, that it will be in next version (https://www.gurux.fi/comment/28057)
Thank you.
6 months 2 weeks ago
Hi, Yes, this is supported…
Yes, this is supported in Java and Net, but this is not implemented in GXDLMSDirector.
Set the ClientPublicKeyCertificate to the client and it's sent with AARQ.
enemy235
Thank you, I will try that. …
I'm working with a new meter, that needs the certificate in AARQ and also it needs digital signature on all messages. I was going through the code and I don't know, if/how it can be enabled. Is digital signatures of all mesages implemented in Java version?
6 months 1 week ago
Hi, Yes, digital signature…
Yes, digital signature is supported in Java.
You need to set the private and public keys to the client's KeyAgreementKeyPair
and they are used after the connection is established.
Somethiing like this:
//Load the client's private key.
GXPkcs8 key = GXPkcs8.load(path);
// Load the server's public key.
GXx509Certificate cert = GXx509Certificate.load(path);
dlms.getCiphering().setKeyAgreementKeyPair(new KeyPair(cert.getPublicKey(), key.getPrivateKey()));
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
