By Harshi_554, 8 August, 2025 Forums Gurux DLMS for ANSI C How to compile GuruxDLMSDataCollector with wirepas ? Im getting compilation error when I tried make command inside wirepas folder. Hi, Have you installed… Hi, Have you installed Wirepas SDK? Can you describe what error you are receiving? BR, Mikko I have installed wirepas… I have installed wirepas gateway sdk. Im getting below error GuruxDLMSDataCollector/wirepas/gurux_dc$ make makefile:125: *** Too many open files. Stop. Hi, You need to ask Wirepas… Hi, You need to ask Wirepas what might cause this. This works without problems with our environment. BR, Mikko Does this source code works… Does this source code works with all Wirepas SDKs? I used 2.4GHz SDK. Hi, Yes, it should work. BR,… Hi, Yes, it should work. BR, Mikko
