  2. Image Transfer-Data Block Unavailable
By Jimmy, 2 August, 2025
Hi, Mikko,
I'm developing a Java program to make image transfer, the meter is DLMS/COSEM conformed. During the upgrading process, the meter fw upgrading has been enabled, the image transfer has been initiated, but when the first image block is sent, I got an datablock unavailable error message. I continued to transfer all the blocks,and always get the above same error message. After all the blocks have been sent, I read the block status, all of them are 0. I searched here, and didn't find any clear illustration of datablock unavailable. By the way, the 1st transferred block is numbered 000000.
Jimmy
7 months ago
Hi Jimmy, Verify that you…
Hi Jimmy,
Verify that you write the correct firmware. Check the Image transfer initiate message and that your image size and identifier are correct.
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSImageTransfer
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
