  2. Access Vs Access 3
Access vs Access 3
By JavierDiaz, 25 July, 2025
I read the association.
Object 0.0.96.1.19.255 has access
"<Access>13</Access>".
Director display in filed Access - "NoAccess".
Before read this attribute I use a condition
if (_client.CanRead(obj, index))
that returns - true.
Feld "Access" of this attribute has a value "ReadWrite"
Feld "Access3" of this attribute has a value "NoAccess" and this is correct.
Please tell me how to make it return the value "NoAccess"?
Thanks.
3 months ago
Hi, The Association Logical…
The Association Logical Name version #3 is using Access3 and versions #0, #1 and #2 are using Access.
You can give access rights in svr_getAttributeAccess.
https://github.com/Gurux/GuruxDLMS.c/blob/cf91e941aec6135e8ff70cd5b3d50…
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
  • Failed to receive reply from the device in given time.
