  2. Svr_postWrite: Args->size Always Zero
svr_postWrite: args->size Always Zero
By andale8592, 16 July, 2025
Gurux DLMS for ANSI C
I'm currently developing using the example provided here:
https://github.com/Gurux/GuruxDLMS.c/tree/master/GuruxDLMSSimpleServerE…
I've noticed that in the svr_postWrite function, the args->size parameter is always zero. As a result, the loop inside that function never executes.
Here is the relevant source code:
https://github.com/Gurux/GuruxDLMS.c/blob/136207781359516d959ee0c3ebf26…
Could you please confirm if this is expected behavior or if there's something I might be missing?
Best regards,
Alessandro
4 months 2 weeks ago
Hi Alessandro, Have you…
Hi Alessandro,
Have you modified the source code? I just checked this and args->size was one as expected.
  • Wed, 12/10/2025 - 08:45
    gurux.dlms.java 4.0.85
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • GXTIME Conversion Issue
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
  • SNRM byte mening
