  2. DLMS Over LoraWan In Water Metering
DLMS over LoraWan in water metering
By labasvakaras, 15 July, 2025
Hello, wanted to ask a question, maybe you will have some insights.
We are trying to find a solution to launch DLMS over Lorawan. One thing is that our product is battery-powered water meter.
I have questions:
1. Maybe you have real life examples that this was done before?
2. time / Duty cycle - this time is very strict in lorawan, how it is possible to overcome this barrier when DLMS handshake takes up to 6-12 telegrams?
3 months 2 weeks ago
Hi, I believe that the best…
I believe that the best way to do this is if the meter uses push messages.
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSPushSetup
DLMS and LoRa are not an easy combination.
labasvakaras
if i am using push setup and…
if i am using push setup and push messages, do I need to establish communication with AARQ/AARE messages?
Hi, AARQ/AARE are not used…
AARQ/AARE are not used with Push messages. The meter sends only the data, and a connection to the meter is not established.
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
  • Failed to receive reply from the device in given time.
