  2. DLMS Data Gateway Communication With Meters
DLMS Data gateway communication with meters
By Harshi_554, 3 July, 2025
Gurux DLMS for ANSI C
Hiii
As per the dlms datagateway source , the gateway will communicate with the smart meter using serial port (HDLC) communication. Is it possible to communicate with the smart meters using TCP/IP (Wrapper) communication using ethernet?
4 months 3 weeks ago
Hi, Yes, it's possible. You…
Yes, it's possible. You need just change interface type from HDLC to WRAPPER and establish the TCP/IP connection to the meter.
Harshi_554
Hi , Thank you for the reply…
Hi ,
Thank you for the reply.
Where I need to do the required changes? Can you share the changes?
Hi, You need to establish…
You need to establish the TCP/IP connection to the meter in com_open.
Now it's using serial port. Then change
cl_init(&clientCon.settings, 1, 16, 1, DLMS_AUTHENTICATION_NONE, NULL, DLMS_INTERFACE_TYPE_HDLC);
to this:
cl_init(&clientCon.settings, 1, 16, 1, DLMS_AUTHENTICATION_NONE, NULL, DLMS_INTERFACE_TYPE_WRAPPER);
The used settings depend on your meter.
Harshi_554
4 months 2 weeks ago
Thank you for the response…
Thank you for the response. It helped me a lot.
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • SNRM byte mening
