  2. Writing To Meter Objects Using Python Client
Writing to meter objects using python client
By Harshi_554, 23 June, 2025
Hii
I'm using below Gurux python client to read meter data.
https://github.com/Gurux/Gurux.DLMS.Python
Now I want to write to the meter objects. Is all the object attributes of a meter is writable? How to check it?
How to write meter objects using gurux python client?
7 months ago
Hi, You can check it by…
You can check it by calling getAccess. Something like this:
if obj.getAccess(ATTRIBUTE_INDEX) and int(AccessMode.WRITE) != 0:
self.write(obj, ATTRIBUTE_INDEX)
Harshi_554
7 months ago
Hii , Thank you for your…
Hii ,
Thank you for your reply. Now I got to know how to check object's access rights.
How the write(obj, ATTRIBUTE_INDEX) performs SET operation from client to server? If we are passing only object and attribute number to this function, how the new value is set in the meter? Where it will take the parameter for value? I want to perform SET operation from client to server.
7 months ago
Hi, It depends from the…
It depends from the COSEM object what you want to write.
You just set new value and then write it.
For e.g. timezone to clock
clock = GXDLMSClock()
clock.timeZone = 60
self.write(clock, 3)
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
Harshi_554
6 months 4 weeks ago
Thanks a lot for your reply
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Generic Profile- gxGet with selector=2: different behaviour on cpp and cimplementation
  • DLMS Client–Server Communication Over GPRS Fails With Dynamic IP
  • Pre-established connection questions
  • writing Error "Service not allowed"
  • High GMAC meters can’t authenticate – can’t read invocation counter
