  2. Unable To Read Parameter Values From Landis+Gyr E550 Meter Using GXDLMSDirector - NoAccess Status
Unable to read parameter values from Landis+Gyr E550 meter using GXDLMSDirector - NoAccess status
By smartsoftware, 19 June, 2025
Hi everyone,
I'm using GXDLMSDirector to connect to a Landis+Gyr E550 meter. The connection is established successfully, and I can read the basic DLMS/OBIS object structure.
However, I'm facing an issue when trying to read the actual parameter values - most attributes return a NoAccess status. As a result, I can't retrieve the data.
I've attempted to switch the authentication level to Low and High, using the commonly known passwords 00000000 and 12345678, but access to these attributes remains blocked.
Has anyone encountered this with the Landis+Gyr E550 meter?
Any help or suggestions would be greatly appreciated. Thanks!
smartsoftware
2 weeks 6 days ago
Add screenshots <a href=…
Add screenshots:
https://ibb.co/S7MdDrpc
https://ibb.co/k20BGz8q
https://ibb.co/mrpyhhrP
2 weeks 1 day ago
Hi, Did you refresh the…
Did you refresh the association view after you connected with Low or High authentication? You must do it by selecting "File" and "Refresh".
smartsoftware
2 weeks 1 day ago
This button is inactive…
This button is inactive because I cannot connect to the meter in Low or High mode. I can only connect in None mode.
2 weeks 1 day ago
Hi, You can only read values…
You can only read values without authentication. Have you tried to connect with Authentication level: "Management Access" or "Data Collection"?
The correct password should be on the meter documentation. If you don't own the meter, it might be changed.
  • Wed, 07/09/2025 - 16:41
    Gurux.Serial.Android 2.0.13
  • Wed, 07/09/2025 - 12:07
    gurux.dlms.c 9.0.2507.0901
  • Sat, 07/05/2025 - 15:04
    Gurux.DLMS.Python 1.0.188
  • Tue, 07/01/2025 - 10:09
    Gurux.DLMS.Python 1.0.187
  • Tue, 07/01/2025 - 09:54
    gurux.dlms.c 9.0.2507.0101
  • Regarding the dlms android project
  • Unable to read attribute =3 (1.0.94.91.0.255) IC=7 for Indian Metering, while I'm able to read attribute 3 for other Profile generic class
  • Register Activation class (class_id = 9) attribute index 3 data is not visible
  • Load profile
  • DLMS Decryption Implementation Status and Clarification Needed
