  2. DLMS Server Connection Using Serial Port
DLMS server connection using serial port
By Harshi_554, 5 June, 2025
Gurux DLMS for ANSI C
Is it possible to communicate with the dlms server (which I'm using as virtual smart meter using PC) using serial port connection from dlms client?
6 months 1 week ago
Hi, ANSI C example meter…
ANSI C example meter uses only TCP/IP ports. Client supports serial port and TCP/IP connections.
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • Thu, 12/11/2025 - 11:01
    gurux.dlms.java 4.0.86
  • Wed, 12/10/2025 - 08:45
    gurux.dlms.java 4.0.85
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Inhemeter i210 dlms director
  • Gurux.Net
  • GXTIME Conversion Issue
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
