  2. HDLC Adress Resolver Configuration
HDLC Adress resolver configuration
By Basv@1, 23 May, 2025
Hello. It is possible to add the option to select a number (address) а Logical server? According to the logs, addresses are scanned from logical address 0, but the energymeter can work as a logical device with address 1, etc.
Basv@1
9 months 2 weeks ago
*address
*address
Hi, You can create HDLC…
You can create HDLC server address from a logical and physical addresses with the GetServerAddress method
GXDLMSClient.GetServerAddress(1, 1);
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
