  2. Simulator Connection Closed
Simulator connection closed
By Mahaveer, 21 May, 2025
Gurux.Net
I have created 100 simulator in Gurux.DLMS.Simulator.Net project with start port 1000 to 1099, and it's working fine but randomly closes connection for some ports when I connect it from code or director tool.
Can you please suggest me the solution, as per my requirement it should always connect and response data as it is running in my local system.
7 months 3 weeks ago
Hi, I believe that…
I believe that inactivity time causes this.
This might sometimes happen if you establish two connections to the same port.
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • 6-digit field values from meter not fully received (only 5 digits shown)
  • Gurux DLMS Android App
