  2. Contadores Landys Bloqueados
Contadores Landys bloqueados
By Rosa, 8 May, 2025
Gurux DLMS for Android
Buenas tardes,
He experimentado con todos los contadores LGZ que he probado que, si pongo una dirección de cliente errónea, el contador se bloquea temporalmente (1-2 minutos) y no me permite reconectarme usando la dirección de cliente correcta en ese tiempo, sin embargo, si cambio cualquier otro parámetro, aunque de error para conectarse, luego me permite conectarme al instante. He probado con otros contadores como ZIV, Sagecom... y ninguno me ha dado ese problema, solo me ocurre con LGZ.
¿Porqué ocurre esto? ¿Habéis detectado este error?
6 months ago
Hi, If you don't close the…
If you don't close the connection correctly, the meter doesn't answer during the inactivity timeout. If this happens when you try to connect to the meter and the meter doesn't accept the connection, then I believe that this is a meter issue.
You should ask the meter vendor whether a firmware update is available to fix this issue.
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
  • Failed to receive reply from the device in given time.
