  2. Failed At Conformance Test
Failed at Conformance Test
By MikeAtson1, 8 May, 2025
I already shared a message about that. Still not found solution. And also I tried Landis+Gyr E550 meter.
Starting to execute test for ll.
Starting HDLC tests #1.
Receiver Ready failed.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc1">Test #1 failed.</a>Starting HDLC tests #2.
Timeout.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc2">Test #2 failed.</a>Starting HDLC tests #3.
Timeout.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc3">Test #3 failed.</a>Starting HDLC tests #4.
Timeout.HDLC Illecal frame test (Opening flag missing).
HDLC Illecal frame test (Closing flag missing).
HDLC Test #4. HDLC Illecal frame test (Both flags are missing).
Timeout.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc4">Test #4 failed.</a>Starting HDLC tests #5.
Timeout.SNRM request failed. Failed to receive reply from the device in given time.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc5">Test #5 failed.</a>Starting HDLC tests #6.
Timeout.
like that. Those are also failed.
This is last test between Gxdirector and Stm - Dlms Stack
11:51:52 Initializing serial connection.
11:51:53 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
11:51:53
7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
11:51:53 Parsing UA reply succeeded.
11:51:53 Send AARQ request.
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 88 55 7E
11:51:53
7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 02 00 00 07 7A ED 7E
11:51:53 Parsing AARE reply succeeded.
11:51:53 Disconnect request
11:51:53 HDLC test #1. Disconnect request
7E A0 07 03 21 53 03 C7 7E
11:51:53
11:51:53 HDLC test #1. SNRM request
11:51:53
11:51:53 HDLC test #1. Receiver Ready
7E A0 07 03 21 11 15 A6 7E
11:52:18 Data send failed. Try to resend 1/3
11:52:18
7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 97 2B E1 7E
11:52:18 Disconnect request
11:52:18 HDLC test #1. Disconnect request
11:52:18
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
  • Failed to receive reply from the device in given time.
