when i connect through GXdlms Director i got error
Exception Response "Service Unknown" -Exception Deciphering failed.
what can i do for firmware upgrade OBIS code and give profer information
14:44:10 Send SNRM request.
TX: 7E A0 07 03 A1 93 C3 8D 7E
14:44:10
RX: 7E A0 1E A1 03 73 2F 76 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
14:44:10 Send AARQ request.
TX: 7E A0 4C 03 A1 10 F2 ED E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 56 33 29 04 37 72 38 15 34 31 20 3E 45 1B 55 45 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF DE 4A 7E
14:44:10
RX: 7E A0 0F A1 03 30 AA D9 E6 E7 00 D8 02 05 70 2F 7E
14:44:10
Hi, You need to use a…
You need to use a ciphered connection. Select "Secured connections" and change security to AuthenticationEncryption and set block cipher and authentication keys.
Default block cipher: 000102030405060708090A0B0C0D0E0F
Default authentication key: D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF
i given proper credential…
i given proper credential for our design
for addAssociationHighGMacPreEstablished() 0, 0, 40, 0, 5, 255
password: 1234567890123456
selected authentication and encryption
client ID: lnt00000
Authentication key : 1234567890123456
block ciphered key : 1234567890123456
associationHigh.clientSAP = 0x50;
i given proper credential then also i am getting
can you suggest any other solution....
reply above question...
when i am using…
when i am using GURUXdlmsserverexample2 , doing authentication firmware upgrade, invocation counter(0.0.43.1.5.255) not increasing can you give updated version for firmware upgrade in server side
int addAssociationHighGMacPreEstablished()
int ret;
const unsigned char ln[6] = { 0, 0, 40, 0, 5, 255 };
if ((ret = INIT_OBJECT(associationHighGMacPreEstablished,
DLMS_OBJECT_TYPE_ASSOCIATION_LOGICAL_NAME, ln)) == 0) {
associationHighGMacPreEstablished.authenticationMechanismName.mechanismId =DLMS_AUTHENTICATION_HIGH;
// DLMS_AUTHENTICATION_HIGH_GMAC;
OA_ATTACH(associationHighGMac.objectList, ALL_OBJECTS);
associationHighGMacPreEstablished.clientSAP = 0x50;
associationHighGMacPreEstablished.xDLMSContextInfo.maxSendPduSize =
associationHighGMacPreEstablished.xDLMSContextInfo.maxReceivePduSize =
PDU_BUFFER_SIZE;
associationHighGMacPreEstablished.xDLMSContextInfo.conformance =
(DLMS_CONFORMANCE) (DLMS_CONFORMANCE_BLOCK_TRANSFER_WITH_ACTION
| DLMS_CONFORMANCE_BLOCK_TRANSFER_WITH_SET_OR_WRITE
| DLMS_CONFORMANCE_BLOCK_TRANSFER_WITH_GET_OR_READ
| DLMS_CONFORMANCE_SET
| DLMS_CONFORMANCE_SELECTIVE_ACCESS
| DLMS_CONFORMANCE_ACTION
| DLMS_CONFORMANCE_MULTIPLE_REFERENCES
| DLMS_CONFORMANCE_GET);
// GMAC authentication don't need password.
#ifndef DLMS_IGNORE_OBJECT_POINTERS
associationHighGMacPreEstablished.securitySetup =
&securitySetupHighGMacPreEstablished;
#else
memcpy(associationHighGMacPreEstablished.securitySetupReference, securitySetupHighGMacPreEstablished.base.logicalName, 6);
#endif // DLMS_IGNORE_OBJECT_POINTERS
return ret;
i follow above association i am getting below error
