  2. If The Latest Software Not Support Wi-SUN(such As Class_id = 95, 96,97,98)
if the Latest software not support Wi-SUN(such as class_id = 95, 96,97,98)
By holley-cgd, 29 April, 2025
I Downloaded the latest DLMSDirector, connect and read Association is OK. But the resault is not include the "Wi-SUN setup (class_id = 95, version 0)", In fact, the data frame contains this data item. Some data frames are intercepted as follows:
12 00 5F 11 00 09 06 00 00 22 00 00 FF 02 02
01 0F
02 03 0F 01 16 01 00
02 03 0F 02 16 03 00
02 03 0F 03 16 03 00
02 03 0F 04 16 03 00
02 03 0F 05 16 03 00
02 03 0F 06 16 03 00
02 03 0F 07 16 03 00
02 03 0F 08 16 03 00
02 03 0F 09 16 03 00
02 03 0F 0A 16 03 00
02 03 0F 0B 16 03 00
02 03 0F 0C 16 03 00
02 03 0F 0D 16 00 00
02 03 0F 0E 16 03 00
02 03 0F 0F 16 03 00
6 months 1 week ago
Hi, Wi-SUN support has not…
Wi-SUN support has not been implemented yet, as there hasn't been customer demand so far. It is planned for the future, but the timeline is still uncertain.
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
  • Failed to receive reply from the device in given time.
