  2. Hwo To Connect To Genus Meter Via HighSHA256?
hwo to connect to Genus meter via HighSHA256?
By P3NCYUYkUtQkKX64H, 23 April, 2025
The "Authentication" drop-down for Genus meters only shows "None", "Low", and "HighGMAC". how do i add "HighSHA256" to that list? yes, the meter definitely supports mechanism 6.
I see that the goe.obx file that's downloaded from the website only has those 3, but I can't see a way to edit that file, and I can't see a way to do this in the Manufacturer Settings dialog, either.
1 month ago
Hi, Genus hasn't sent any…
Genus hasn't sent any meter that supports HighSHA256 to us, but I believe you that it's supported. Restart GXDLMSDirector and select "New Manufacturer Settings Available" from the top menu. After that HighSHA256 support for Genus is available.
P3NCYUYkUtQkKX64H
1 month ago
thanks!
thanks!
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Mon, 05/19/2025 - 10:19
    gurux.net.java 1.0.30
  • Mon, 05/19/2025 - 10:00
    gurux.dlms.c 9.0.2505.1901
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • HDLC Adress resolver configuration
  • Reading all "Data" object type parameter together
  • com_read getting failed for billing profile and instantaneous profile
  • Simulator connection closed
  • Regarding the dlms android project
