  2. Wrapper Connection In Java
Wrapper connection in java
By niralldas8@gmail.com, 17 April, 2025
Getting error like this,
C:\Users\COMP\Downloads\gurux.dlms.java-master\gurux.dlms.client.example.java>java -jar target\gurux.dlms.client.example.java-0.0.1-SNAPSHOT.jar -S COM4:115200:8NoneOne -i WRAPPER -c 48 -a High -P ABCDEFGH12345678 -C AuthenticationEncryption -T 4C54434C49454E54 -A 31323334353637383930313233343536 -B 31323334353637383930313233343536 -v 0.0.43.1.3.255 -d India -t Verbose
WARNING: A restricted method in java.lang.System has been called
WARNING: java.lang.System::load has been called by gurux.serial.GXSerial in an unnamed module (file:/C:/Users/COMP/Downloads/gurux.dlms.java-master/gurux.dlms.client.example.java/target/gurux.dlms.client.example.java-0.0.1-SNAPSHOT.jar)
WARNING: Use --enable-native-access=ALL-UNNAMED to avoid a warning for callers in this module
WARNING: Restricted methods will be blocked in a future release unless native access is enabled
Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Users\COMP\AppData\Local\Temp\gurux.serial.java11082750769555113252.dll: Can't find dependent libraries
at java.base/jdk.internal.loader.NativeLibraries.load(Native Method)
at java.base/jdk.internal.loader.NativeLibraries$NativeLibraryImpl.open(NativeLibraries.java:321)
at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:187)
at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:129)
at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2245)
at java.base/java.lang.Runtime.load0(Runtime.java:767)
at java.base/java.lang.System.load(System.java:1624)
at gurux.serial.GXSerial.initialize(GXSerial.java:326)
at gurux.serial.GXSerial.<init>(GXSerial.java:178)
at gurux.dlms.client.Settings.getParameters(Settings.java:341)
at gurux.dlms.client.sampleclient.main(sampleclient.java:83)
10 months 2 weeks ago
Hi, I believe that you haven…
I believe that you haven't built the Maven project.
run:
mvn package
And try again.
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
