  3. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd , 17 April, 2025
Gurux DLMS for Android
In GXDLMSDirector, I was able to successfully read data without explicitly setting the baud rate. However, in the Android application, selecting a baud rate is mandatory — there's no option to leave it unset. Even after selecting the same baud rate as used in GXDLMSDirector, the Android app fails to retrieve any data.
1 year 7 months ago
Hi, The baudrate is always…
The baudrate is always mandatory.
Are you using HDLC or HdlcWithModeE in GXDLMSDirector. GXDLMSDirector uses the 9600 as a default value with HDLC.
atuldd
1 year 7 months ago
Are you using HDLC? yes i am…
Are you using HDLC?
yes i am using HDLC after giving 9600 as a default value with HDLC also i am not getting response from the meter
1 year 7 months ago
Hi, What chipset USB to RS…
What chipset USB to RS-232 use? Are you using the same cable in Windows and Android?
atuldd
1 year 7 months ago
It is USB and i am using the…
It is USB and i am using the same cable in android and windows
1 year 7 months ago
Hi, Select "Media Settings"…
Select "Media Settings" and then select "Info". Who is the manufacturer, and what are the vendor and Product ID?
atuldd
1 year 6 months ago
manufacture info: L&T MPS L…
L&T MPS E-Meter USB Optic Port
Vendor: Future Technology devices international
product: FT232 Serial(UART) IC ID:6001
chipset:FTDI
atuldd
1 year 6 months ago
while (!succeeded) { …
i am getting the error has Failed to recieve reply from the device in given time
1 year 6 months ago
Hi, Please, don't add…
Please, don't add example code. It doesn't help.
The meter doesn't send a reply for some reason. Can you select "Show trace" in Android. What is the hex string that the client sends?
atuldd
1 year 6 months ago
now i can able to open How…
How can i get the Register data like Energy-wh(Imp,Exp), Energy-vah(Imp,Exp)
i got the list of OBIS codes by comparing the DLMS director i selected Energy-wh(Imp)
and clicked on read it gave me a set of hexa decimal values in the right
i want to know where in the android application we are getting the values like in DLMS director
please help me in this
atuldd
1 year 6 months ago
<- 18:34:31.573 7E A0 19 03…
<- 18:34:31.573 7E A0 19 03 41 32 3A BD E6 E6 00 C0 01 C1 00 07 01 00 62 01 00 FF 01 00 17 A7 7E
-> 18:34:31.700 7E A0 18 41 03 52 9F 04 E6 E7 00 C4 01 C1 00 09 06 01 00 62 01 00 FF 58 FA 7E
<- 18:34:31.705 7E A0 19 03 41 54 0A BB E6 E6 00 C0 01 C1 00 07 01 00 62 01 00 FF 03 00 A7 94 7E
-> 18:34:32.004 7E A8 89 41 03 74 FF E8 E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 03 F2 01 64 02 04 12 00 03 09 06 00 00 00 01 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 08 00 FF 0F 02 12 00 00 02 04 12 6C 00 7E
<- 18:34:32.011 7E A0 07 03 41 71 46 A0 7E
<- 18:34:37.019 7E A0 07 03 41 71 46 A0 7E
-> 18:34:37.275 7E A8 89 41 03 76 ED CB 00 03 09 06 01 00 06 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 07 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 08 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 00 00 5E 5B 0D FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0D 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 54 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 01 FF 0F 02 12 00 00 02 04 12 00 03 1B F8 7E
<- 18:34:37.284 7E A0 07 03 41 91 48 47 7E
-> 18:34:37.498 7E A8 89 41 03 78 93 22 09 06 01 00 09 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 6C 2B 7E
<- 18:34:37.508 7E A0 07 03 41 B1 4A 66 7E
-> 18:34:37.737 7E A8 89 41 03 7A 81 01 01 00 01 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 08 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 08 05 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 16 BF 7E
if i select the OBIS and read i am getting this show trace
how can i find the value out of this
because billing profile data will be huge please help me with this
