  2. Porting My App To Linux
Porting my App to Linux
By vasil_gurux, 25 March, 2025
Hi! I have complete working desktop app on win with gurux, and i'm thinkig about porting my app on linux.
Except new UI, what is the main steps, I need to do (or consider to do or do nothing) with Gurux libraries? Sorry, if my question little bit stupud or so) I'm new to such a task and linux.
Thanks in advance).
9 months 3 weeks ago
Hi, You didn't tell what…
You didn't tell what programming language you want to use, but communication client examples are already implemented, e.g., Java, Python, and C#. You need to implement the UI.
vasil_gurux
C# WPF
C# WPF
Hi, You can get the example…
You can get the example client here:
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E…
I propose that you use MAUI instead of WPF.
vasil_gurux
I have started test project…
I have started test project on Avalonia, and it works fine, except i have some problem with serial ports on my Ubuntu. Need to solve problem with access denied on serial port. As I know NET MAUI not works on Linux but Windows, macOS, iOS, and Android
9 months 2 weeks ago
Hi, You are right. I didn't…
You are right. I didn't remember that Linux is not supported.
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • 6-digit field values from meter not fully received (only 5 digits shown)
  • Gurux DLMS Android App
