Hi , I try to connect with DlmsDirector on Sagemcom XT211 meter . I choose the manufacturer from the drop down menu (sagemcom energy & telecom) and when I try to make connection I receive that error "manufacturer type does not much. Manufacturer is SAG and should be SET".
Is possible to fix the issue with software??
Hi, It seems that Sagemcom…
It seems that Sagemcom Energy & Telecom has reserved two flag IDs with the same name.
Restart GXDLMSDirecor and select "New Manufacturer Settings Available" from the top menu.
Sagemcom Energy & Telecom (SAG) is added to manufacturers.
Select it and you should be able to read your meter.
