  2. Kelin Electric Meter Error - Gurux.DLMS.AMI.Agent.Worker.GXAgentWorker[0]
By oodeyemi, 25 January, 2025
Gurux.DLMS.AMI
HI,
I get this error: "Gurux.DLMS.AMI.Agent.Worker.GXAgentWorker[0] Failed to establish the connection. Value cannot be null. (Parameter 'PortName')" after connecting the agent and adding a new task. The connection is successful but once a task is added, it throws the error above.
Thanks for your help.
11 months 3 weeks ago
Hi, I believe that you try…
I believe that you try to communicate with serial port. This error occurs because your serial port is not selected in the agent settings.
oodeyemi
10 months ago
Thank you. Could you please…
Thank you.
Could you please provide guidance on where/how I can set the serial port in the agent settings?
10 months ago
Hi, Select the agent and…
Select the agent and select the serial port that you want to use with the agent.
GXDLMSDirector has set the correct serial port settings and those will be used.
oodeyemi
9 months 3 weeks ago
Thanks for the support.
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • 6-digit field values from meter not fully received (only 5 digits shown)
  • Gurux DLMS Android App
