  2. Issues With Reading Kelin Electric Meter Using Gurux Python Code
Issues with reading Kelin Electric Meter using Gurux Python code
By Ali.khan, 22 January, 2025
Gurux.DLMS.AMI
I have been using the Gurux DLMS python code with Kelin Electric Smart Meter. The meter gives me values using the DLMS director but when I use the Python code it gives me gibberish or invalid Data.
Has anyone else faced this problem? How should I be able to get the correct data using the Python code.
10 months 2 weeks ago
Hi, Use the command line…
Use the command line arguments when you select your meter in GXDLMSDirector.
Can you describe what data is wrong?
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • SNRM byte mening
