  2. Communication From Rs485 Port of Meter To Gurux Director
Communication from Rs485 port of meter to Gurux Director
By aee1software@g…, 9 January, 2025
I have connected the meter RS485 to PC USB port via Rs485-USB convertor.
The virtual port is created by PC and it is listing.
But Director shows error "Device doesnot exists was specified"
Genus meter is connected and the same can be read thru Director thru Optical port.
Any help in this regard is appreciated
11 months 1 week ago
Hi, I believe that one of…
I believe that one of your RS-485 settings is different than the meter expect.
Check the baud rate first.
Have you tried to find the address with HDLC Address resolver?
https://youtu.be/BeaWKmyMwuE?si=1Ht3RXyig-OBz16i
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • Thu, 12/11/2025 - 11:01
    gurux.dlms.java 4.0.86
  • Wed, 12/10/2025 - 08:45
    gurux.dlms.java 4.0.85
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Inhemeter i210 dlms director
  • Gurux.Net
  • GXTIME Conversion Issue
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
