  2. GXDLMSScriptTable and ExecuteScript
Profile picture for user gaurang
By gaurang, 1 January, 2025
Gurux.DLMS.AMI
Is AMI4 Agent and AMI4 server/client support script execution on Remote DLMS Meters?
Is they any example to customize it and achieve script execution functionality?
Best Regards,
Gaurang
11 months ago
Hi Gaurang, There is no UI…
Hi Gaurang,
There is no UI for ScriptTable at the moment in Gurux DLMS AMI.
It's possible to do with calling Swagger, but it's not easy. I'll add the ScriptTable support to the work list, but I can't tell when it can be released.
gaurang
11 months ago
Thank you Mikko, I will try…
Thank you Mikko,
I will try with Swagger way.
Best Regards,
Gaurang
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • SNRM byte mening
  • Itron SL7000 load profile return error
