  2. Push Setup Not Sending Push Notification When Set Using Gurux Java Code
Push Setup not sending push notification when set using gurux java code
By sc-anokum, 20 December, 2024
i'm using iskra meter, when i use the tool provided by iskra meter to set the destination, and execute the push i do get the push notification on the listener, but when i use gurux library to set the destination ip and port and execute the push, i donot receive any push notification no matter how many times i try, on comparing TX for both scenario, i found that it differs only in priority and invokeid.
below are the parsed xml's
working xml :
<WRAPPER len="46" >
<TargetAddress Value="1" />
<SourceAddress Value="1" />
<PDU>
<SetRequest>
<SetRequestNormal>
<!--Priority: NORMAL ServiceClass: CONFIRMED invokeID: 1-->
<InvokeIdAndPriority Value="65" />
<AttributeDescriptor>
<!--PUSH_SETUP-->
<ClassId Value="40" />
<!--0.4.25.9.0.255-->
<InstanceId Value="0004190900FF" />
<AttributeId Value="3" />
</AttributeDescriptor>
<Value>
<Structure Qty="3" >
<Enum Value="0" />
<!--removed ip and port from the xml-->
<OctetString Value="removed ip intentionally" />
<Enum Value="0" />
</Structure>
</Value>
</SetRequestNormal>
</SetRequest>
</PDU>
</WRAPPER>
request not working
<WRAPPER len="46" >
<PDU>
<SetRequest>
<SetRequestNormal>
<!--Priority: HIGH ServiceClass: CONFIRMED invokeID: 1-->
<InvokeIdAndPriority Value="193" />
<!--PUSH_SETUP-->
<Value>
<Enum Value="0" />
<Enum Value="0" />
</Structure>
</Value>
</SetRequestNormal>
</SetRequest>
</PDU>
</WRAPPER>
1 year 3 months ago
Hi, You can try to change…
You can try to change the service class. That should not usually make the difference, but there are differences between the meters.
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
