  2. Month Bill Read By Date Range Not Working
Month Bill read by date range not working
By mightyChamp, 20 December, 2024
From DLMS meter we can read data of Load Survey and Daily Load by Date range , but for Month Bill we can't read by Date range.
So, Is there any method to read Month Bill by Date range?
Thank You
10 months 2 weeks ago
Hi, Some meters doesn't…
Some meters doesn't implement read by range or entry to Month Bill and expect that Month Bill is read with normal read. Something like this:
Read(pg, 2);
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
  • Failed to receive reply from the device in given time.
