  2. Convert Logfile.txt To CDF/JSON.
Convert logfile.txt to CDF/JSON.
By Kumaresh, 5 December, 2024
Hi Kurumi ji,
Can you guide us how to convert the logfile.txt into cdf/xml/txt or JSON or any other format where TX and RX are not placed.
Just the profile name the header in column and meter data with RTC in rows.
Am using python master.
11 months ago
Hi, DLMS is a binary format…
DLMS is a binary format. Converting logfile.txt directly to JSON is not possible, but you can convert data with GXDLMSTranslator.
https://gurux.fi/FAQ
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
  • Failed to receive reply from the device in given time.
