  2. Python Code For Getting Data Using Optical Probe
Python code for getting data using optical probe
By Ganesh123, 15 November, 2024
Gurux.Serial
We require simple Python code to read from check meters using DLMS and an optical probe USB cable.
8 months ago
Hi, You can use Python…
You can use Python client example for that.
https://github.com/Gurux/Gurux.DLMS.Python/
  • Wed, 07/09/2025 - 16:41
    Gurux.Serial.Android 2.0.13
  • Wed, 07/09/2025 - 12:07
    gurux.dlms.c 9.0.2507.0901
  • Sat, 07/05/2025 - 15:04
    Gurux.DLMS.Python 1.0.188
  • Tue, 07/01/2025 - 10:09
    Gurux.DLMS.Python 1.0.187
  • Tue, 07/01/2025 - 09:54
    gurux.dlms.c 9.0.2507.0101
  • DLMS communication issue when routing through VPN on Android
  • ESP32-Based Smart Meter Interface via DLMS/COSEM
  • svr_postWrite: args->size Always Zero
  • DLMS over LoraWan in water metering
  • Update High password - any way to cipher new password
