  2. L&T ER300P - RS232 Communication Cable (PL2303)
L&T ER300P - RS232 Communication cable (PL2303)
By skbohra, 7 November, 2024
I am using a PL2303 based USB to RS232 converter which has 4 wire (TX, RX, GND, VCC).
I have connected RJ11 (4 pin) connector as per the meter ER300P datasheet.
I am yet to test this cable with the meter, wanted to confirm if this will work as I don't have access to the meter and need to test the cable in the field.
Any help on this is highly appreciated.
1 year 5 months ago
Hi, Buy the USB to RJ11…
Buy the USB to RJ11 converter. It will save a lot of your time.
skbohra
1 year 5 months ago
Mikko, Can you suggest…
Mikko,
Can you suggest tested cable for this meter? Any link to buy?
1 year 5 months ago
Hi, There are no big…
There are no big differences between RJ11 cables. Optical probes are a different story.
The only thing you need to check is that the USB driver works with your PC. Some (cheap) USB dongles don't support Windows 11.
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
