  2. DLMS OPTICAL METER READING
By Shine, 12 October, 2024
Dear Sir,
I have read the values of the L&T meter using the DMLS director and optical cable. It is working perfectly, and its interface settings are HDLC with MR authentication
After that, I am trying to read the L&T meter using Arduino. In the Arduino development folder, it shows three programs: client, server, and pushListener. From these which programs should I use for meter reading using HDLC with MR authentication
1 year 4 months ago
Hi, With client you can read…
With client you can read your meter. Just set the same arguments that you are using with GXDLMSDirector.
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
