  2. GXDLMSRegisterMonitor Write Attr 4 Actions Bug
GXDLMSRegisterMonitor write Attr 4 actions bug
By xsmy, 12 October, 2024
when i write GXDLMSRegisterMonitor actions Attribute value error occurs "Access Error : Device reports a unmatched type."
When checking the source code, I found that the Java version of getvalue was inconsistent with the C# code. The correct one seemed to be ARRAY, while the Java code was written as STRUCTURE.
Java Code:
public final Object getValue(GXDLMSSettings settings, ValueEventArgs e) {
if (e.getIndex() == 1) {
return GXCommon.logicalNameToBytes(this.getLogicalName());
} else if (e.getIndex() == 2) {
return this.getThresholds();
} else {
GXByteBuffer bb;
if (e.getIndex() == 3) {
bb = new GXByteBuffer();
bb.setUInt8(DataType.STRUCTURE.getValue());
bb.setUInt8(3);
GXCommon.setData(settings, bb, DataType.UINT16, this.monitoredValue.getObjectType().getValue());
GXCommon.setData(settings, bb, DataType.OCTET_STRING, GXCommon.logicalNameToBytes(this.monitoredValue.getLogicalName()));
GXCommon.setData(settings, bb, DataType.INT8, this.monitoredValue.getAttributeIndex());
return bb.array();
} else if (e.getIndex() != 4) {
e.setError(ErrorCode.READ_WRITE_DENIED);
return null;
} else {
if (this.actions == null) {
bb.setUInt8(0);
} else {
bb.setUInt8(this.actions.length);
GXDLMSActionSet[] var4 = this.actions;
int var5 = var4.length;
for(int var6 = 0; var6 < var5; ++var6) {
GXDLMSActionSet it = var4[var6];
bb.setUInt8((byte)DataType.STRUCTURE.getValue());
bb.setUInt8(2);
bb.setUInt8(2);
GXCommon.setData(settings, bb, DataType.OCTET_STRING, GXCommon.logicalNameToBytes(it.getActionUp().getLogicalName()));
GXCommon.setData(settings, bb, DataType.UINT16, it.getActionUp().getScriptSelector());
bb.setUInt8(2);
GXCommon.setData(settings, bb, DataType.OCTET_STRING, GXCommon.logicalNameToBytes(it.getActionDown().getLogicalName()));
GXCommon.setData(settings, bb, DataType.UINT16, it.getActionDown().getScriptSelector());
return bb.array();
C# Code
object IGXDLMSBase.GetValue(GXDLMSSettings settings, ValueEventArgs e)
if (e.Index == 1)
return GXCommon.LogicalNameToBytes(LogicalName);
if (e.Index == 2)
return this.Thresholds;
if (e.Index == 3)
GXByteBuffer data = new GXByteBuffer();
data.SetUInt8((int)DataType.Structure);
data.SetUInt8(3);
GXCommon.SetData(settings, data, DataType.UInt16, MonitoredValue.ObjectType); //ClassID
GXCommon.SetData(settings, data, DataType.OctetString, GXCommon.LogicalNameToBytes(MonitoredValue.LogicalName)); //Logical name.
GXCommon.SetData(settings, data, DataType.Int8, MonitoredValue.AttributeIndex); //Attribute Index
return data.Array();
if (e.Index == 4)
data.SetUInt8((int)DataType.Array);
if (Actions == null)
data.SetUInt8(0);
else
data.SetUInt8((byte)Actions.Length);
foreach (GXDLMSActionSet it in Actions)
data.SetUInt8(2);
data.SetUInt8(2);
GXCommon.SetData(settings, data, DataType.OctetString, GXCommon.LogicalNameToBytes(it.ActionUp.LogicalName)); //Logical name.
GXCommon.SetData(settings, data, DataType.UInt16, it.ActionUp.ScriptSelector); //ScriptSelector
data.SetUInt8(2);
GXCommon.SetData(settings, data, DataType.OctetString, GXCommon.LogicalNameToBytes(it.ActionDown.LogicalName)); //Logical name.
GXCommon.SetData(settings, data, DataType.UInt16, it.ActionDown.ScriptSelector); //ScriptSelector
e.Error = ErrorCode.ReadWriteDenied;
return null;
1 year 5 months ago
Hi, Thank you for pointing…
Thank you for pointing this out. This is now fixed to Java version 4.0.71.
Get the latest version.
xsmy
1 year 5 months ago
thanks
thanks
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
