  2. Сhanging Parameters of The Arbitrator Class
Сhanging parameters of the arbitrator class
By eduard.ch, 30 September, 2024
Hello!
Can you add any button that allows the user to update the arbitrator parameters? Or can you explain how to set new values ​​if this feature is already added?
Thanks in advance
7 months 3 weeks ago
Hi, You can change the…
You can change the parameters if you modify them and then write it to the meter.
I notest that the permissions and weightings table are missing from the UI.
They will be added to the next version.
eduard.ch
I'll look forward to it…
I'll look forward to it. Thanks!
andre538
4 months 1 week ago
Hello, as far as I see there…
as far as I see there is still no UI ability to change permissions and weightings table values for Arbitrator class?
BR, Andrew
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Mon, 05/19/2025 - 10:19
    gurux.net.java 1.0.30
  • Mon, 05/19/2025 - 10:00
    gurux.dlms.c 9.0.2505.1901
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • HDLC Adress resolver configuration
  • Reading all "Data" object type parameter together
  • com_read getting failed for billing profile and instantaneous profile
  • Simulator connection closed
  • Regarding the dlms android project
