I'm trying to read DTS-353/100A/V4D from the YTL manufacturer (Zhejiang Yongtailong Electronic ,Co., LTD). I don't have any manual and couldn't find it on the internet.
Using the HDLC Address Resolver I could establish a connection to the meter using the RS485 serial port with the following configuration:
Interface: HDLC
Logical Name Referencing
Authentication: None
Client Address: 16 (decimal)
Address Type: Default:
Logical Server: 10 (decimal)
Physical Server 9058 (decimal)
serial 9600-8-N-1
I could read the object list:
0.0.1.0.0.255 Clock object #1
0.0.40.0.1.255 Current association
0.0.40.0.1.255 Association # 1
0.0.41.0.0.255 SAP Assgiment
0.0.42.0.0.255 COSEM Logical device name
But I'm looking for measuring information such as voltage, current, energies, etc. Could you guide me on how to do so?
Thanks.
Hi, I believe that you need…
I believe that you need to use a different client address and authentication level to access other information. The problem is that the client address can be anything. It's not defined in the DLMS standards.
You can use HDLC Address Resolver to check if it finds any other client addresses. The problem is that I don't know what authentication level those addresses use. You need to try and test with different settings.
The best and fastest option is if you get the correct settings from the meter vendor.
