i was wondering, can i use simulator without physical meter, so that i can test my program via serial port or net? The plan is, i want to create arduino program for ESP that can receive and send data back to meter using hdlc protocol. So can i create that program and try to test in the Gurux GXDLMSDirector only to see if the program really works?
Hi, You don't need the real…
You don't need the real meter. You can use crystal.xml template and modify it for your needs.
Hi, how do i implement…
how do i implement crystal.xml template?
Hi, It's available with the…
It's available with the source codes.
https://github.com/Gurux/Gurux.DLMS.Net/blob/master/Gurux.DLMS.Simulato…
