I am facing some issues randomly with some meters. It doesn't happens always, just in some random lectures.
I attach you the last part of the Log and the error my Android app throws
Do you know why that error is thrown? Can i do something to solve it?
TX: 7EA014022103BA35BEE6E600C002C10000008A8A847E
RX: 7EA10A0300020021DABEE0E6E700C402C4000000008B0081F00208090C07E8061D06110000008000801100060000454C06000000000600001A7C0600000000060000000006000000000208090C07E8061D061200000080008011000600005024060000000006000021E00600000000060000000006000000000208090C07E8061D061300000080008011000600003FC90600000000060000161E0600000000060000000006000000000208090C07E8061D061400000080008011000600004B7506000000000600001ACE0600000000060000000006000000000208090C07E8061D061500000080008011000600004AD406000000000600001ADA0600000000060000000006000000003CA87E
TX: 7EA014022103DC05B8E6E600C002C10000008B03957E
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
TX: 7EA014022103FE15BAE6E600C002C10000008CBCE17E
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
TX: 7EA0140221031065B4E6E600C002C10000008D35F07E
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
TX: 7EA0140221033275B6E6E600C002C10000008EAEC27E
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
TX: 7EA0140221035445B0E6E600C002C10000008F27D37E
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
TX: 7EA0140221037655B2E6E600C002C100000090513B7E
RX: 7EA07A03000200219625F8E6E700C402C401000000910081600208090C07E8061E07170000008000801100060000377C0600000000060000103E0600000000060000000006000000000208090C07E807010100000000800080110006000036F50600000000060000105B06000000000600000000060000000010867E
MeterApp crash stacktrace ->
java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.String gurux.dlms.enums.DataType.toString()' on a null object reference
at gurux.dlms.enums.DataType.forValue(DataType.java:163)
at gurux.dlms.internal.GXCommon.getData(GXCommon.java:524)
at gurux.dlms.internal.GXCommon.getArray(GXCommon.java:693)
at gurux.dlms.internal.GXCommon.getData(GXCommon.java:540)
at gurux.dlms.GXDLMS.getValueFromData(GXDLMS.java:3690)
at gurux.dlms.GXDLMS.getPdu(GXDLMS.java:3437)
at gurux.dlms.GXDLMS.getData(GXDLMS.java:3773)
at gurux.dlms.GXDLMSClient.getData(GXDLMSClient.java:2407)
at gurux.dlms.GXDLMSClient.getData(GXDLMSClient.java:2358)
at net.gisce.giscedistri.serial.DLMS.SerialJava.readDLMSPacket(SerialJava.java:486)
at net.gisce.giscedistri.serial.DLMS.SerialJava.readDataBlock(SerialJava.java:543)
at net.gisce.giscedistri.serial.DLMS.SerialJava.readDataBlock(SerialJava.java:523)
at net.gisce.giscedistri.serial.DLMS.SerialJava.readRowsByRange(SerialJava.java:391)
at net.gisce.giscedistri.serial.DLMS.SerialJava.onExecute(SerialJava.java:788)
at net.gisce.giscedistri.serial.GXTask.doInBackground(GXTask.java:82)
at net.gisce.giscedistri.serial.GXTask.doInBackground(GXTask.java:42)
at android.os.AsyncTask$3.call(AsyncTask.java:394)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:305)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
at java.lang.Thread.run(Thread.java:923)
Thank you so much.
BR
The value the method 'public…
The value the method 'public static DataType forValue(final int value) {...}' receives is a 193 (is an int), so i do not know if that could help you to know why is that happening.
The weird thing is that I read that same meter right after this error happened and the reading finished well.
I attach you the failed log and the successful log in different comments, so you can take a look at both of them. They both are asked to the same meter, the first one failed and the second one was successfull.
Hope that'd helps.
BR
Log FAILED execution TX:…
TX: 7EA0080221039386C17E
RX: 7EA0170300020021734CC2818008050200FF060200FF87717E
TX: 7EA0450221031043CAE6E6006036A1090607608574050801018A0207808B0760857405080201AC0A80083937333233383138BE10040E01000000065F1F0400001E1DFFFF19A47E
RX: 7EA03A0300020021301FFFE6E7006129A109060760857405080101A203020100A305A103020100BE10040E0800065F1F040000181D00FC000761E57E
TX: 7EA01A02210332CDD7E6E600C001C100010000600104FF020065D27E
RX: 7EA0220300020021522ED4E6E700C401C400090D5A49563030333536303039373969197E
TX: 7EA01A02210354FDD1E6E600C001C100030100011D00FF0300FEE37E
RX: 7EA019030002002174D230E6E700C401C40002020F00161E00437E
TX: 7EA04D022103765396E6E600C001C100070100630100FF0201010204020412000809060000010000FF0F02120000090C07E8060106000000FFFF8880090C07E8070101000000FFFF88800100157F7E
RX: 7EA0DE030002002196CD72E6E700C402C400000000010081C4018202D10208090C07E8060106000000008000801100060000329A0600000000060000260C0600000000060000000006000000000208090C07E806010601000000800080110406000033B9060000000006000025D00600000000060000000006000000000208090C07E80601060200000080008011040600003362060000000006000025A60600000000060000000006000000000208090C07E80601060300000080008011000600003911060000000006000025F2060000000006000000000600000000374E7E
TX: 7EA0140221039825BCE6E600C002C10000000151BE7E
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
TX: 7EA014022103BA35BEE6E600C002C100000002CA8C7E
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
TX: 7EA014022103DC05B8E6E600C002C100000003439D7E
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
TX: 7EA014022103FE15BAE6E600C002C100000004FCE97E
RX: 7EA10A03000200211E9660E6E700C402C400000000050081F00208090C07E806010613000000800080110406000000770600006ACF06000000DD0600002ABA060000000006000000000208090C07E80601061400000080008011000600000993060000094906000019A40600001058060000000006000000000208090C07E80601061500000080008011000600001C7D060000057D06000020FA0600000724060000000006000000000208090C07E806010616000000800080110006000032F0060000000006000027E30600000000060000000006000000000208090C07E806010617000000800080110006000032540600000000060000265E060000000006000000000600000000117B7E
TX: 7EA0140221031065B4E6E600C002C10000000575F87E
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
TX: 7EA0140221033275B6E6E600C002C100000006EECA7E
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
TX: 7EA0140221035445B0E6E600C002C10000000767DB7E
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
TX: 7EA0140221037655B2E6E600C002C10000000890237E
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
TX: 7EA0140221039825BCE6E600C002C10000000919327E
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
TX: 7EA014022103BA35BEE6E600C002C10000000A82007E
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
TX: 7EA014022103DC05B8E6E600C002C10000000B0B117E
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
TX: 7EA014022103FE15BAE6E600C002C10000000CB4657E
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
TX: 7EA0140221031065B4E6E600C002C10000000D3D747E
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
TX: 7EA0140221033275B6E6E600C002C10000000EA6467E
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
TX: 7EA0140221035445B0E6E600C002C10000000F2F577E
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
TX: 7EA0140221037655B2E6E600C002C10000001059BF7E
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
TX: 7EA0140221039825BCE6E600C002C100000011D0AE7E
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
TX: 7EA014022103BA35BEE6E600C002C1000000124B9C7E
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
TX: 7EA014022103DC05B8E6E600C002C100000013C28D7E
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
TX: 7EA014022103FE15BAE6E600C002C1000000147DF97E
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
TX: 7EA0140221031065B4E6E600C002C100000015F4E87E
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
TX: 7EA0140221033275B6E6E600C002C1000000166FDA7E
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
TX: 7EA0140221035445B0E6E600C002C100000017E6CB7E
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
TX: 7EA0140221037655B2E6E600C002C10000001811337E
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
TX: 7EA0140221039825BCE6E600C002C10000001998227E
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
TX: 7EA014022103BA35BEE6E600C002C10000001A03107E
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
TX: 7EA014022103DC05B8E6E600C002C10000001B8A017E
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
TX: 7EA014022103FE15BAE6E600C002C10000001C35757E
RX: 7EA10A03000200211E9660E6E700C402C4000000001D0081F00208090C07E80606041300000080008011040600000000060000747206000000000600002861060000000006000000000208090C07E806060414000000800080110006000000D20600002F5B060000029706000025AB060000000006000000000208090C07E80606041500000080008011000600001326060000036B0600001D030600000AA9060000000006000000000208090C07E806060416000000800080110006000030E90600000000060000257E0600000000060000000006000000000208090C07E8060604170000008000801100060000355A060000000006000024E9060000000006000000000600000000D7857E
TX: 7EA0140221031065B4E6E600C002C10000001DBC647E
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
TX: 7EA0140221033275B6E6E600C002C10000001E27567E
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
TX: 7EA0140221035445B0E6E600C002C10000001FAE477E
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
TX: 7EA0140221037655B2E6E600C002C100000020DA8E7E
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
TX: 7EA0140221039825BCE6E600C002C100000021539F7E
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
TX: 7EA014022103BA35BEE6E600C002C100000022C8AD7E
RX: 7EA10A0300020021DABEE0E6E700C402C400000000230081F00208090C07E80608060100000080008011040600003F5F060000000006000032E70600000000060000000006000000000208090C07E80608060200000080008011040600004062060000000006000032CF0600000000060000000006000000000208090C07E80608060300000080008011000600004002060000000006000031860600000000060000000006000000000208090C07E8060806040000008000801104060000419A0600000000060000334B0600000000060000000006000000000208090C07E8060806050000008000801100060000431A060000000006000032D9060000000006000000000600000000A4FC7E
TX: 7EA014022103DC05B8E6E600C002C10000002341BC7E
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
TX: 7EA014022103FE15BAE6E600C002C100000024FEC87E
RX: 7EA10A03000200211E9660E6E700C402C400000000250081F00208090C07E80608060B0000008000801100060000038C06000010100600000F3006000032C1060000001706000001150208090C07E80608060C0000008000801104060000004E0600002CD9060000015106000040D7060000000006000000000208090C07E80608060D000000800080110406000000000600006CA50600000000060000388E060000000006000000000208090C07E80608060E0000008000801100060000000006000092C5060000000006000039BD060000000006000000000208090C07E80608060F00000080008011000600000000060000A5D3060000000006000039D306000000000600000000E76F7E
TX: 7EA0140221031065B4E6E600C002C10000002577D97E
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
TX: 7EA0140221033275B6E6E600C002C100000026ECEB7E
RX: 7EA10A030002002152FEE8E6E700C402C400000000270081F00208090C07E8060806150000008000801100060000300A060000000006000035280600000000060000000006000000000208090C07E80608061600000080008011000600003F98060000000006000033FA0600000000060000000006000000000208090C07E80608061700000080008011000600003F580600000000060000338B0600000000060000000006000000000208090C07E8060907000000008000801100060000433B060000000006000033DE0600000000060000000006000000000208090C07E806090701000000800080110406000040BC060000000006000031C30600000000060000000006000000002EB67E
TX: 7EA0140221035445B0E6E600C002C10000002765FA7E
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
TX: 7EA0140221037655B2E6E600C002C10000002892027E
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
TX: 7EA0140221039825BCE6E600C002C1000000291B137E
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
TX: 7EA014022103BA35BEE6E600C002C10000002A80217E
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
TX: 7EA014022103DC05B8E6E600C002C10000002B09307E
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
TX: 7EA014022103FE15BAE6E600C002C10000002CB6447E
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
TX: 7EA0140221031065B4E6E600C002C10000002D3F557E
RX: 7EA10A030002002130EAA8E6E700C402C4000000002E0081F00208090C07E8060A01080000008000801100060000AE1E060000000006000037860600000000060000000006000010F00208090C07E8060A010900000080008011000600008E7A06000000000600002EC60600000000060000000006000019BE0208090C07E8060A010A000000800080110006000040200600000041060000346806000002E806000000020600001B8A0208090C07E8060A010B00000080008011000600001F66060000066106000031100600001E6006000000A606000002A10208090C07E8060A010C00000080008011000600000BA80600001BBB0600000DFF060000471C06000001750600000530ADEB7E
TX: 7EA0140221033275B6E6E600C002C10000002EA4677E
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
TX: 7EA0140221035445B0E6E600C002C10000002F2D767E
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
TX: 7EA0140221037655B2E6E600C002C1000000305B9E7E
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
TX: 7EA0140221039825BCE6E600C002C100000031D28F7E
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
TX: 7EA014022103BA35BEE6E600C002C10000003249BD7E
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
TX: 7EA014022103DC05B8E6E600C002C100000033C0AC7E
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
TX: 7EA014022103FE15BAE6E600C002C1000000347FD87E
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
TX: 7EA0140221031065B4E6E600C002C100000035F6C97E
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
TX: 7EA0140221033275B6E6E600C002C1000000366DFB7E
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
TX: 7EA0140221035445B0E6E600C002C100000037E4EA7E
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
TX: 7EA0140221037655B2E6E600C002C10000003813127E
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
TX: 7EA0140221039825BCE6E600C002C1000000399A037E
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
TX: 7EA014022103BA35BEE6E600C002C10000003A01317E
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
TX: 7EA014022103DC05B8E6E600C002C10000003B88207E
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
TX: 7EA014022103FE15BAE6E600C002C10000003C37547E
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
TX: 7EA0140221031065B4E6E600C002C10000003DBE457E
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
TX: 7EA0140221033275B6E6E600C002C10000003E25777E
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
TX: 7EA0140221035445B0E6E600C002C10000003FAC667E
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
TX: 7EA0140221037655B2E6E600C002C100000040DCED7E
RX: 7EA10A030002002196D668E6E700C402C400000000410081F00208090C07E8060E05070000008000801100060000AC10060000000006000001F50600000000060000000006000024860208090C07E8060E05080000008000801100060000CC4F0600000000060000100E060000000006000000000600000C1E0208090C07E8060E0509000000800080110006000088180600000000060000044E0600000000060000000006000008C00208090C07E8060E050A000000800080110406000048EC060000000006000019410600000000060000000006000003E30208090C07E8060E050B00000080008011000600001623060000062806000009FF06000002F506000001BA06000001FB54E97E
TX: 7EA0140221039825BCE6E600C002C10000004155FC7E
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
TX: 7EA014022103BA35BEE6E600C002C100000042CECE7E
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
TX: 7EA014022103DC05B8E6E600C002C10000004347DF7E
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
TX: 7EA014022103FE15BAE6E600C002C100000044F8AB7E
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
TX: 7EA0140221031065B4E6E600C002C10000004571BA7E
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
TX: 7EA0140221033275B6E6E600C002C100000046EA887E
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
TX: 7EA0140221035445B0E6E600C002C10000004763997E
RX: 7EA10A030002002174CAACE6E700C402C400000000480081F00208090C07E8060F061200000080008011000600000000060000A12F06000000020600004A62060000000006000000000208090C07E8060F06130000008000801100060000000006000073A2060000000006000049C9060000000006000000000208090C07E8060F06140000008000801100060000007C0600002BB0060000020606000046E3060000000006000000000208090C07E8060F06150000008000801100060000199C06000000B50600003D2D06000008D1060000000006000000000208090C07E8060F061600000080008011000600003C610600000000060000451A06000000000600000000060000000056DB7E
TX: 7EA0140221037655B2E6E600C002C10000004894617E
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
TX: 7EA0140221039825BCE6E600C002C1000000491D707E
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
TX: 7EA014022103BA35BEE6E600C002C10000004A86427E
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
TX: 7EA014022103DC05B8E6E600C002C10000004B0F537E
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
TX: 7EA014022103FE15BAE6E600C002C10000004CB0277E
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
TX: 7EA0140221031065B4E6E600C002C10000004D39367E
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
TX: 7EA0140221033275B6E6E600C002C10000004EA2047E
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
TX: 7EA0140221035445B0E6E600C002C10000004F2B157E
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
TX: 7EA0140221037655B2E6E600C002C1000000505DFD7E
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
TX: 7EA0140221039825BCE6E600C002C100000051D4EC7E
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
TX: 7EA014022103BA35BEE6E600C002C1000000524FDE7E
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
TX: 7EA014022103DC05B8E6E600C002C100000053C6CF7E
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
TX: 7EA014022103FE15BAE6E600C002C10000005479BB7E
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
TX: 7EA0140221031065B4E6E600C002C100000055F0AA7E
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
TX: 7EA0140221033275B6E6E600C002C1000000566B987E
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
TX: 7EA0140221035445B0E6E600C002C100000057E2897E
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
TX: 7EA0140221037655B2E6E600C002C10000005815717E
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
TX: 7EA0140221039825BCE6E600C002C1000000599C607E
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
TX: 7EA014022103BA35BEE6E600C002C10000005A07527E
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
TX: 7EA014022103DC05B8E6E600C002C10000005B8E437E
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
TX: 7EA014022103FE15BAE6E600C002C10000005C31377E
RX: 7EA10A03000200211E9660E6E700C402C4000000005D0081F00208090C07E806140403000000800080110006000044E6060000000006000033CA0600000000060000000006000000000208090C07E8061404040000008000801104060000435B060000000006000033C30600000000060000000006000000000208090C07E806140405000000800080110006000046530600000000060000327E0600000000060000000006000000000208090C07E8061404060000008000801100060000554B060000000006000036B50600000000060000000006000000000208090C07E8061404070000008000801100060000ACA806000000000600004402060000000006000000000600000D4D2FCC7E
TX: 7EA0140221031065B4E6E600C002C10000005DB8267E
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
TX: 7EA0140221033275B6E6E600C002C10000005E23147E
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
TX: 7EA0140221035445B0E6E600C002C10000005FAA057E
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
TX: 7EA0140221037655B2E6E600C002C100000060DECC7E
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
TX: 7EA0140221039825BCE6E600C002C10000006157DD7E
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
TX: 7EA014022103BA35BEE6E600C002C100000062CCEF7E
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
TX: 7EA014022103DC05B8E6E600C002C10000006345FE7E
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
TX: 7EA014022103FE15BAE6E600C002C100000064FA8A7E
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
TX: 7EA0140221031065B4E6E600C002C100000065739B7E
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
TX: 7EA0140221033275B6E6E600C002C100000066E8A97E
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
TX: 7EA0140221035445B0E6E600C002C10000006761B87E
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
TX: 7EA0140221037655B2E6E600C002C10000006896407E
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
TX: 7EA0140221039825BCE6E600C002C1000000691F517E
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
TX: 7EA014022103BA35BEE6E600C002C10000006A84637E
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
TX: 7EA014022103DC05B8E6E600C002C10000006B0D727E
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
TX: 7EA014022103FE15BAE6E600C002C10000006CB2067E
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
TX: 7EA0140221031065B4E6E600C002C10000006D3B177E
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
TX: 7EA0140221033275B6E6E600C002C10000006EA0257E
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
TX: 7EA0140221035445B0E6E600C002C10000006F29347E
RX: 7EA10A030002002174CAACE6E700C402C400000000700081F00208090C07E806180102000000800080110406000041A906000000000600003B050600000000060000000006000000000208090C07E8061801030000008000801100060000440806000000000600003CBA0600000000060000000006000000000208090C07E8061801040000008000801104060000404006000000000600003C730600000000060000000006000000000208090C07E806180105000000800080110006000041D806000000000600003C8A0600000000060000000006000000000208090C07E8061801060000008000801100060000462C06000000000600003D520600000000060000000006000000006B437E
TX: 7EA0140221037655B2E6E600C002C1000000705FDC7E
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
TX: 7EA0140221039825BCE6E600C002C100000071D6CD7E
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
TX: 7EA014022103BA35BEE6E600C002C1000000724DFF7E
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
TX: 7EA014022103DC05B8E6E600C002C100000073C4EE7E
RX: 7EA10A0300020021FC8AA4E6E700C402C400000000740081F00208090C07E80618011600000080008011000600003C2406000000000600003D550600000000060000000006000000000208090C07E8061801170000008000801100060000403006000000000600003B600600000000060000000006000000000208090C07E80619020000000080008011000600003FA506000000000600003BF10600000000060000000006000000000208090C07E80619020100000080008011040600003F0506000000000600003A2D0600000000060000000006000000000208090C07E8061902020000008000801104060000408706000000000600003B0006000000000600000000060000000023907E
TX: 7EA014022103FE15BAE6E600C002C1000000747B9A7E
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
TX: 7EA0140221031065B4E6E600C002C100000075F28B7E
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
TX: 7EA0140221033275B6E6E600C002C10000007669B97E
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
TX: 7EA0140221035445B0E6E600C002C100000077E0A87E
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
TX: 7EA0140221037655B2E6E600C002C10000007817507E
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
TX: 7EA0140221039825BCE6E600C002C1000000799E417E
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
TX: 7EA014022103BA35BEE6E600C002C10000007A05737E
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
TX: 7EA014022103DC05B8E6E600C002C10000007B8C627E
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
TX: 7EA014022103FE15BAE6E600C002C10000007C33167E
RX: 7EA10A03000200211E9660E6E700C402C4000000007D0081F00208090C07E8061A03130000008000801100060000013C060000263B0600000B7C0600004DF4060000000006000000000208090C07E8061A031400000080008011000600001A3F060000015A060000504D06000008A2060000000006000000000208090C07E8061A031500000080008011000600003C31060000000006000059D40600000000060000000006000000AF0208090C07E8061A031600000080008011000600004C84060000000006000056330600000000060000000006000000000208090C07E8061A031700000080008011000600004CE60600000000060000571B060000000006000000000600000000FE677E
TX: 7EA0140221031065B4E6E600C002C10000007DBA077E
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
TX: 7EA0140221033275B6E6E600C002C10000007E21357E
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
TX: 7EA0140221035445B0E6E600C002C10000007FA8247E
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
TX: 7EA0140221037655B2E6E600C002C100000080D02B7E
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
TX: 7EA0140221039825BCE6E600C002C100000081593A7E
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
TX: 7EA014022103BA35BEE6E600C002C100000082C2087E
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
TX: 7EA014022103DC05B8E6E600C002C1000000834B197E
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
TX: 7EA014022103FE15BAE6E600C002C100000084F46D7E
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
TX: 7EA0140221031065B4E6E600C002C1000000857D7C7E
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
TX: 7EA0140221033275B6E6E600C002C100000086E64E7E
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
TX: 7EA0140221035445B0E6E600C002C1000000876F5F7E
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
TX: 7EA0140221037655B2E6E600C002C10000008898A77E
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
TX: 7EA0140221039825BCE6E600C002C10000008911B67E
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
TX: 7EA014022103BA35BEE6E600C002C10000008A8A847E
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
TX: 7EA014022103DC05B8E6E600C002C10000008B03957E
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
TX: 7EA014022103FE15BAE6E600C002C10000008CBCE17E
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
TX: 7EA0140221031065B4E6E600C002C10000008D35F07E
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
TX: 7EA0140221033275B6E6E600C002C10000008EAEC27E
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
TX: 7EA0140221035445B0E6E600C002C10000008F27D37E
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
TX: 7EA0140221037655B2E6E600C002C100000090513B7E
RX: 7EA07A03000200219625F8E6E700C402C401000000910081600208090C07E8061E071700000080008011000600004B54060000000006000058340600000000060000000006000000000208090C07E80701010000000080008011040600004A76060000000006000056160600000000060000000006000000007F3C7E
Log SUCCESSFUL execution TX:…
TX: 7EA0080221039386C17E
RX: 7EA0170300020021734CC2818008050200FF060200FF87717E
TX: 7EA0450221031043CAE6E6006036A1090607608574050801018A0207808B0760857405080201AC0A80083937333233383138BE10040E01000000065F1F0400001E1DFFFF19A47E
RX: 7EA03A0300020021301FFFE6E7006129A109060760857405080101A203020100A305A103020100BE10040E0800065F1F040000181D00FC000761E57E
TX: 7EA01A02210332CDD7E6E600C001C100010000600104FF020065D27E
RX: 7EA0220300020021522ED4E6E700C401C400090D5A49563030333536303039373969197E
TX: 7EA01A02210354FDD1E6E600C001C100030100011D00FF0300FEE37E
RX: 7EA019030002002174D230E6E700C401C40002020F00161E00437E
TX: 7EA04D022103765396E6E600C001C100070100630100FF0201010204020412000809060000010000FF0F02120000090C07E8060106000000FFFF8880090C07E8070101000000FFFF88800100157F7E
RX: 7EA0DE030002002196CD72E6E700C402C400000000010081C4018202D10208090C07E8060106000000008000801100060000329A0600000000060000260C0600000000060000000006000000000208090C07E806010601000000800080110406000033B9060000000006000025D00600000000060000000006000000000208090C07E80601060200000080008011040600003362060000000006000025A60600000000060000000006000000000208090C07E80601060300000080008011000600003911060000000006000025F2060000000006000000000600000000374E7E
TX: 7EA0140221039825BCE6E600C002C10000000151BE7E
RX: 7EA10A0300020021B8AAA0E6E700C402C400000000020081F00208090C07E806010604000000800080110406000032120600000000060000256F0600000000060000000006000000000208090C07E80601060500000080008011000600003374060000000006000025540600000000060000000006000000000208090C07E806010606000000800080110006000052A306000000000600002CE50600000000060000000006000000000208090C07E80601060700000080008011000600006FB60600000000060000389F0600000000060000000006000001A40208090C07E8060106080000008000801100060000548806000000000600003799060000000006000000000600000048BBAC7E
TX: 7EA014022103BA35BEE6E600C002C100000002CA8C7E
RX: 7EA10A0300020021DABEE0E6E700C402C400000000030081F00208090C07E8060106090000008000801100060000558906000000000600004C1D060000000006000000000600000C8C0208090C07E80601060A0000008000801100060000245406000009380600004B0F060000164506000000C006000004120208090C07E80601060B000000800080110406000001E406000037B006000004300600004DE6060000031006000001100208090C07E80601060C0000008000801100060000024B06000054FA060000031706000016D00600000C6E060000022F0208090C07E80601060D00000080008011040600000000060000D40906000000000600002DAF06000000000600000000FFB07E
TX: 7EA014022103DC05B8E6E600C002C100000003439D7E
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
TX: 7EA014022103FE15BAE6E600C002C100000004FCE97E
RX: 7EA10A03000200211E9660E6E700C100C10004FCE97E0081F00208090C07E806010613000000800080110406000000770600006ACF06000000DD0600002ABA060000000006000000000208090C07E80601061400000080008011000600000993060000094906000019A40600001058060000000006000000000208090C07E80601061500000080008011000600001C7D060000057D06000020FA0600000724060000000006000000000208090C07E806010616000000800080110006000032F0060000000006000027E30600000000060000000006000000000208090C07E806010617000000800080110006000032540600000000060000265E0600000000060000000006000000000E887E
TX: 7EA0140221031065B4E6E600C002C10000000575F87E
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
TX: 7EA0140221033275B6E6E600C002C100000006EECA7E
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
TX: 7EA0140221035445B0E6E600C002C10000000767DB7E
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
TX: 7EA0140221037655B2E6E600C002C10000000890237E
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
TX: 7EA0140221039825BCE6E600C002C10000000919327E
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
TX: 7EA014022103BA35BEE6E600C002C10000000A82007E
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
TX: 7EA014022103DC05B8E6E600C002C10000000B0B117E
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
TX: 7EA014022103FE15BAE6E600C002C10000000CB4657E
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
TX: 7EA0140221031065B4E6E600C002C10000000D3D747E
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
TX: 7EA0140221033275B6E6E600C002C10000000EA6467E
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
TX: 7EA0140221035445B0E6E600C002C10000000F2F577E
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
TX: 7EA0140221037655B2E6E600C002C10000001059BF7E
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
TX: 7EA0140221039825BCE6E600C002C100000011D0AE7E
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
TX: 7EA014022103BA35BEE6E600C002C1000000124B9C7E
RX: 7EA10A0300020021DABEE0E6E700C402C400000000130081F00208090C07E806040211000000800080110006000001FD060000B78606000004C8060000253C060000000006000000000208090C07E806040212000000800080110006000003EE060000863106000007B1060000205D060000000006000000000208090C07E806040213000000800080110006000009130600004EAF0600000B570600001CA1060000000006000000000208090C07E8060402140000008000801100060000015F0600002E19060000049406000023B7060000000006000000000208090C07E8060402150000008000801100060000126E060000021A0600001DFE06000008CF060000000006000000001C7C7E
TX: 7EA014022103DC05B8E6E600C002C100000013C28D7E
RX: 7EA10A0300020021FC8AA4E6E700C402C400000000140081F00208090C07E806040216000000800080110006000030D5060000000006000026BB0600000000060000000006000000000208090C07E80604021700000080008011000600003591060000000006000026B60600000000060000000006000000000208090C07E8060503000000008000801100060000387A060000000006000026750600000000060000000006000000000208090C07E806050301000000800080110406000035BE060000000006000026160600000000060000000006000000000208090C07E806050302000000800080110406000035FE060000000006000025B1060000000006000000000600000000FF0D7E
TX: 7EA014022103FE15BAE6E600C002C1000000147DF97E
RX: 7EA10A03000200211E9660E6E700C402C400000000150081F00208090C07E806050303000000800080110006000034BA0600000000060000262B0600000000060000000006000000000208090C07E80605030400000080008011040600003871060000000006000026C00600000000060000000006000000000208090C07E806050305000000800080110006000037DF060000000006000025900600000000060000000006000000000208090C07E806050306000000800080110006000055D70600000000060000359506000000000600000000060000000B0208090C07E8060503070000008000801104060000AABC06000000000600005238060000000006000000000600000B5853D17E
TX: 7EA0140221031065B4E6E600C002C100000015F4E87E
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
TX: 7EA0140221033275B6E6E600C002C1000000166FDA7E
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
TX: 7EA0140221035445B0E6E600C002C100000017E6CB7E
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
TX: 7EA0140221037655B2E6E600C002C10000001811337E
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
TX: 7EA0140221039825BCE6E600C002C10000001998227E
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
TX: 7EA014022103BA35BEE6E600C002C10000001A03107E
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
TX: 7EA014022103DC05B8E6E600C002C10000001B8A017E
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
TX: 7EA014022103FE15BAE6E600C002C10000001C35757E
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
TX: 7EA0140221031065B4E6E600C002C10000001DBC647E
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
TX: 7EA0140221033275B6E6E600C002C10000001E27567E
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
TX: 7EA0140221035445B0E6E600C002C10000001FAE477E
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
TX: 7EA0140221037655B2E6E600C002C100000020DA8E7E
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
TX: 7EA0140221039825BCE6E600C002C100000021539F7E
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
TX: 7EA014022103BA35BEE6E600C002C100000022C8AD7E
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
TX: 7EA014022103DC05B8E6E600C002C10000002341BC7E
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
TX: 7EA014022103FE15BAE6E600C002C100000024FEC87E
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
TX: 7EA0140221031065B4E6E600C002C10000002577D97E
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
TX: 7EA0140221033275B6E6E600C002C100000026ECEB7E
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
TX: 7EA0140221035445B0E6E600C002C10000002765FA7E
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
TX: 7EA0140221037655B2E6E600C002C10000002892027E
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
TX: 7EA0140221039825BCE6E600C002C1000000291B137E
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
TX: 7EA014022103BA35BEE6E600C002C10000002A80217E
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
TX: 7EA014022103DC05B8E6E600C002C10000002B09307E
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
TX: 7EA014022103FE15BAE6E600C002C10000002CB6447E
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
TX: 7EA0140221031065B4E6E600C002C10000002D3F557E
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
TX: 7EA0140221033275B6E6E600C002C10000002EA4677E
RX: 7EA10A030002002152FEE8E6E700C402C4000000002F0081F00208090C07E8060A010D000000800080110406000001440600003EB506000002F10600005489060000041D060000008D0208090C07E8060A010E00000080008011000600000C1D06000041660600000973060000489E0600000326060000037C0208090C07E8060A010F000000800080110006000007AC0600003F440600000C9C060000351306000003FD060000000A0208090C07E8060A01100000008000801100060000054F0600003254060000037E06000000000600000F25060000000A0208090C07E8060A0111000000800080110406000001960600004F14060000000006000000000600000F5706000000AD0B8E7E
TX: 7EA0140221035445B0E6E600C002C10000002F2D767E
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
TX: 7EA0140221037655B2E6E600C002C1000000305B9E7E
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
TX: 7EA0140221039825BCE6E600C002C100000031D28F7E
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
TX: 7EA014022103BA35BEE6E600C002C10000003249BD7E
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
TX: 7EA014022103DC05B8E6E600C002C100000033C0AC7E
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
TX: 7EA014022103FE15BAE6E600C002C1000000347FD87E
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
TX: 7EA0140221031065B4E6E600C002C100000035F6C97E
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
TX: 7EA0140221033275B6E6E600C002C1000000366DFB7E
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
TX: 7EA0140221035445B0E6E600C002C100000037E4EA7E
RX: 7EA10A030002002174CAACE6E700C402C400000000380081F00208090C07E8060C030A0000008000801100060000365306000003040600002CDE0600000DE006000000E606000012680208090C07E8060C030B0000008000801100060000147F06000028C4060000103A060000279E0600001A1B06000009180208090C07E8060C030C00000080008011000600001EF306000041690600000FF9060000345006000002B606000007050208090C07E8060C030D00000080008011040600000810060000794C060000082406000035AE06000015F206000003120208090C07E8060C030E0000008000801100060000097506000069D20600000F0B060000440D06000003C106000001057A3B7E
TX: 7EA0140221037655B2E6E600C002C10000003813127E
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
TX: 7EA0140221039825BCE6E600C002C1000000399A037E
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
TX: 7EA014022103BA35BEE6E600C002C10000003A01317E
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
TX: 7EA014022103DC05B8E6E600C002C10000003B88207E
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
TX: 7EA014022103FE15BAE6E600C002C10000003C37547E
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
TX: 7EA0140221031065B4E6E600C002C10000003DBE457E
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
TX: 7EA0140221033275B6E6E600C002C10000003E25777E
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
TX: 7EA0140221035445B0E6E600C002C10000003FAC667E
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
TX: 7EA0140221037655B2E6E600C002C100000040DCED7E
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
TX: 7EA0140221039825BCE6E600C002C10000004155FC7E
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
TX: 7EA014022103BA35BEE6E600C002C100000042CECE7E
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
TX: 7EA014022103DC05B8E6E600C002C10000004347DF7E
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
TX: 7EA014022103FE15BAE6E600C002C100000044F8AB7E
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
TX: 7EA0140221031065B4E6E600C002C10000004571BA7E
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
TX: 7EA0140221033275B6E6E600C002C100000046EA887E
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
TX: 7EA0140221035445B0E6E600C002C10000004763997E
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
TX: 7EA0140221037655B2E6E600C002C10000004894617E
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
TX: 7EA0140221039825BCE6E600C002C1000000491D707E
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
TX: 7EA014022103BA35BEE6E600C002C10000004A86427E
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
TX: 7EA014022103DC05B8E6E600C002C10000004B0F537E
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
TX: 7EA014022103FE15BAE6E600C002C10000004CB0277E
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
TX: 7EA0140221031065B4E6E600C002C10000004D39367E
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
TX: 7EA0140221033275B6E6E600C002C10000004EA2047E
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
TX: 7EA0140221035445B0E6E600C002C10000004F2B157E
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
TX: 7EA0140221037655B2E6E600C002C1000000505DFD7E
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
TX: 7EA0140221039825BCE6E600C002C100000051D4EC7E
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
TX: 7EA014022103BA35BEE6E600C002C1000000524FDE7E
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
TX: 7EA014022103DC05B8E6E600C002C100000053C6CF7E
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
TX: 7EA014022103FE15BAE6E600C002C10000005479BB7E
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
TX: 7EA0140221031065B4E6E600C002C100000055F0AA7E
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
TX: 7EA0140221033275B6E6E600C002C1000000566B987E
RX: 7EA10A030002002152FEE8E6E700C402C400000000570081F00208090C07E80612021500000080008011000600002721060000000006000045970600000000060000000006000000000208090C07E806120216000000800080110006000048CF0600000000060000436B0600000000060000000006000000000208090C07E80612021700000080008011000600004B0E060000000006000041440600000000060000000006000000000208090C07E80613030000000080008011000600004B54060000000006000042500600000000060000000006000000000208090C07E80613030100000080008011040600004C420600000000060000438A06000000000600000000060000000031347E
TX: 7EA0140221035445B0E6E600C002C100000057E2897E
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
TX: 7EA0140221037655B2E6E600C002C10000005815717E
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
TX: 7EA0140221039825BCE6E600C002C1000000599C607E
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
TX: 7EA014022103BA35BEE6E600C002C10000005A07527E
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
TX: 7EA014022103DC05B8E6E600C002C10000005B8E437E
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
TX: 7EA014022103FE15BAE6E600C002C10000005C31377E
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
TX: 7EA0140221031065B4E6E600C002C10000005DB8267E
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
TX: 7EA0140221033275B6E6E600C002C10000005E23147E
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
TX: 7EA0140221035445B0E6E600C002C10000005FAA057E
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
TX: 7EA0140221037655B2E6E600C002C100000060DECC7E
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
TX: 7EA0140221039825BCE6E600C002C10000006157DD7E
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
TX: 7EA014022103BA35BEE6E600C002C100000062CCEF7E
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
TX: 7EA014022103DC05B8E6E600C002C10000006345FE7E
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
TX: 7EA014022103FE15BAE6E600C002C100000064FA8A7E
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
TX: 7EA0140221031065B4E6E600C002C100000065739B7E
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
TX: 7EA0140221033275B6E6E600C002C100000066E8A97E
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
TX: 7EA0140221035445B0E6E600C002C10000006761B87E
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
TX: 7EA0140221037655B2E6E600C002C10000006896407E
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
TX: 7EA0140221039825BCE6E600C002C1000000691F517E
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
TX: 7EA014022103BA35BEE6E600C002C10000006A84637E
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
TX: 7EA014022103DC05B8E6E600C002C10000006B0D727E
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
TX: 7EA014022103FE15BAE6E600C002C10000006CB2067E
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
TX: 7EA0140221031065B4E6E600C002C10000006D3B177E
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
TX: 7EA0140221033275B6E6E600C002C10000006EA0257E
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
TX: 7EA0140221035445B0E6E600C002C10000006F29347E
RX: 7EA10A030002002174CAACE6E700C402C400000000700081F00208090C07E806180102000000800080110406000041A906000000000600003B050600000000060000000006000000000208090C07E8061801030000008000801100060000440806000000000600003CBA0600000000060000000006000000000208090C07E8061801040000008000801104060000404006000000000600003C730600000000060000000006000000000208090C07E806180105000000800080110006000041D806000000000600003C8A0600000000060000000006000000000208090C07E8061801060000008000801100060000462C06000000000600003D520600000000060000000006000000006B437E
TX: 7EA0140221037655B2E6E600C002C1000000705FDC7E
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
TX: 7EA0140221039825BCE6E600C002C100000071D6CD7E
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
TX: 7EA014022103BA35BEE6E600C002C1000000724DFF7E
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
TX: 7EA014022103DC05B8E6E600C002C100000073C4EE7E
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
TX: 7EA014022103FE15BAE6E600C002C1000000747B9A7E
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
TX: 7EA0140221031065B4E6E600C002C100000075F28B7E
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
TX: 7EA0140221033275B6E6E600C002C10000007669B97E
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
TX: 7EA0140221035445B0E6E600C002C100000077E0A87E
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
TX: 7EA0140221037655B2E6E600C002C10000007817507E
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
TX: 7EA0140221039825BCE6E600C002C1000000799E417E
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
TX: 7EA014022103BA35BEE6E600C002C10000007A05737E
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
TX: 7EA014022103DC05B8E6E600C002C10000007B8C627E
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
TX: 7EA014022103FE15BAE6E600C002C10000007C33167E
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
TX: 7EA0140221031065B4E6E600C002C10000007DBA077E
RX: 7EA10A030002002130EAA8E6E700C402C4000000007E0081F00208090C07E8061B040000000080008011000600004CC10600000000060000575D0600000000060000000006000000000208090C07E8061B040100000080008011040600004DF30600000000060000577E0600000000060000000006000000000208090C07E8061B040200000080008011040600004D86060000000006000054F80600000000060000000006000000000208090C07E8061B0403000000800080110006000050A3060000000006000056E50600000000060000000006000000000208090C07E8061B040400000080008011040600004CC30600000000060000571D06000000000600000000060000000063C77E
TX: 7EA0140221033275B6E6E600C002C10000007E21357E
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
TX: 7EA0140221035445B0E6E600C002C10000007FA8247E
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
TX: 7EA0140221037655B2E6E600C002C100000080D02B7E
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
TX: 7EA0140221039825BCE6E600C002C100000081593A7E
RX: 7EA10A0300020021B8AAA0E6E700C402C400000000820081F00208090C07E8061B0414000000800080110006000005EE06000008CE060000246D0600002DB6060000000006000000000208090C07E8061B041500000080008011000600002F5406000000000600004EF40600000000060000000006000000000208090C07E8061B041600000080008011000600004CD30600000000060000506F0600000000060000000006000001810208090C07E8061B041700000080008011000600004F53060000000006000052710600000000060000000006000000000208090C07E8061C050000000080008011000600004FD10600000000060000544F060000000006000000000600000000CF1F7E
TX: 7EA014022103BA35BEE6E600C002C100000082C2087E
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
TX: 7EA014022103DC05B8E6E600C002C1000000834B197E
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
TX: 7EA014022103FE15BAE6E600C002C100000084F46D7E
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
TX: 7EA0140221031065B4E6E600C002C1000000857D7C7E
RX: 7EA10A030002002130EAA8E6E700C402C400000000860081F00208090C07E8061C051000000080008011000600000000060000BB0506000000000600005628060000011A06000000000208090C07E8061C051100000080008011000600000000060000A2C406000000000600005D49060000000006000000000208090C07E8061C051200000080008011000600000000060000937006000000000600005CF0060000000006000000000208090C07E8061C05130000008000801100060000000A0600004D7F06000001190600005CDE060000000006000000000208090C07E8061C0514000000800080110006000003D60600000E4C0600001CA80600003ECC06000000000600000000FF517E
TX: 7EA0140221033275B6E6E600C002C100000086E64E7E
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
TX: 7EA0140221035445B0E6E600C002C1000000876F5F7E
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
TX: 7EA0140221037655B2E6E600C002C10000008898A77E
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
TX: 7EA0140221039825BCE6E600C002C10000008911B67E
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
TX: 7EA014022103BA35BEE6E600C002C10000008A8A847E
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
TX: 7EA014022103DC05B8E6E600C002C10000008B03957E
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
TX: 7EA014022103FE15BAE6E600C002C10000008CBCE17E
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
TX: 7EA0140221031065B4E6E600C002C10000008D35F07E
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
TX: 7EA0140221033275B6E6E600C002C10000008EAEC27E
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
TX: 7EA0140221035445B0E6E600C002C10000008F27D37E
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
TX: 7EA0140221037655B2E6E600C002C100000090513B7E
RX: 7EA07A03000200219625F8E6E700C402C401000000910081600208090C07E8061E071700000080008011000600004B54060000000006000058340600000000060000000006000000000208090C07E80701010000000080008011040600004A76060000000006000056160600000000060000000006000000007F3C7E
Hi, The data type 193 is not…
The data type 193 is not defined in DLMS standards. It's invalid and an exception is thrown because of that.
There is something strange with the reads.
Working read jumps from 6/1/2024 1:00:00 PM to 6/2/2024 12:00:00 AM
Where failed read continues normally.
Try to read only 12 hours at a time. That helps with some of the meters.
When saying 'Try to read…
When saying 'Try to read only 12 hours at a time' you mean that I should request data to meters from 12h to 12h?
I normally request hourly profiles for a full month, that's what user needs. Making requests from 12 to 12 hours may be a slow option, isn't it?
Hi, Yes, don't read more…
Yes, don't read more than one day at a time. It might be a little slower option, but it works better. It's also much better with bad connections.
