  2. I Don't Understand The Meaning of Event Code
I don't understand the meaning of event code
By xsmy, 27 July, 2024
Where should I look for the definition of Event code? Is it customized by the meter manufacturer or is there a universal standard?
1 year 6 months ago
Hi, DLMS standard doesn't…
DLMS standard doesn't define the event codes and this causes all meter manufacturers use custom codes. You need to check this from the meter documentation.
If you share the meter model and codes those can be added to the template so they are shown in the future.
xsmy
1 year 6 months ago
Got it, thanks for your…
Got it, thanks for your answer
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Python GXDLMSTranslator
  • Issue with KWH Value Reading Using Gurux DLMS Library.
  • CEWE Prometer 100
