Please let us know in which sequence I call function to read association and profile generic data. Please let us know what code we should write where to save association and profile generic data.
You can use client example to read the association view and all the objects from the association view. The association view is saved to the file if you add -O argument.
Because I don't know what programming language you are using I can't give the exact URL to the example, but you can find them here:
Hi, You can use client…
https://github.com/gurux
