  2. IN GXDLMSClient We Are Not Able To Set Interface Type Giving Error As InterfaceType Is Not Defined.
IN GXDLMSClient we are not able to set interface type giving error as InterfaceType is not defined.
By satishjyoti1998, 9 July, 2024
client = GXDLMSClient()
client.interfaceType = InterfaceType.HDLC
NameError: name InterfaceType is not defined.
10 months 1 week ago
Hi, You must import the…
You must import the InterfaceType like this:
from gurux_dlms.enums import InterfaceType
satishjyoti1998
Hi Mikko, Thanks a lot for…
Thanks a lot for your suggestion. Issue got resolved.
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • Tue, 05/13/2025 - 10:00
    Gurux.DLMS.Android 2.0.15
  • Fri, 05/09/2025 - 13:03
    Gurux.DLMS.Python 1.0.181
  • Wed, 05/07/2025 - 16:09
    Gurux.DLMS.Android 2.0.14
  • Long reading ends with "Invalid frame ..." error.
  • Push listener example how it works + tcp stream issue
  • Problem with reading energymeter Star DTS27 via GXDLMSDirector
  • Receiver Ready Test Failed
  • Combining several meters' profile generic data into one
