I hope this info helps other people in Styria, Austria that want to read out their smart meters.
More info from the nework provider can be found by searching for "e-netze kundenschnittstelle" (https://www.e-netze.at/downloads-data/pdf.aspx?pdf=EN_Update%20Kundensc…). You will need to get your GUEK and GAK keys. I got mine by registering in the web portal and activating the customer interface
Every 10 seconds, data is given out via the M-Bus (RJ12 port, pins 3 and 4) at 2400 Baud, 8N1 or 8E1
For me it looks like this (332 bytes)
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
It consists of 3 HDLC messages (each start and stop with 7E)
Each containing a PDU block
Putting these together we get the full PDU block
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
in this example
4C475A6773D4CBB3 is the system title
0103 is the length. corresponds to 259 bytes after the "0103"
so it seems to be valid
this full PDU block can be deciphered in the Gurus DLMS Translator program tool
- enter your PDU block on the PDU tab
- enter your "system title", "block cipher key"(GUEK) and "authentication key"(GAK) on the ciphering tab
- go back to the PDU tab and click file->PDU to XML
XML data should be displayed
helpful website that explains PDU block structure
https://www.weigu.lu/tutorials/sensors2bus/04_encryption/index.html
helpful website that…
