  2. Transport Endpoint Is Not Connected
Transport endpoint is not connected
By Mahaveer, 28 June, 2024
Gurux.Net
Hi Team,
I have used gurux libararies for read meter data and everything is working fine in my local machine (Windows OS). The same code I have deployed on server where we are using docker container on linux os. On linux meter is not connecting and getting error as below.
SocketException: at Gurux.Net.GXNet.ClientConnect(EndPoint ep)
at Gurux.Net.GXNet.Open()
at CorrelationEngineMS.GuruxDlms.GuruxDLMS.InitDlms(MeterRequest meterRequest)
Can you please suggest me some point, why getting this kind of error.
From server where I deployed same code, I checked telnet of meter IP and port and working fine. But the issue is with .net code it's not connecting.
11 months 3 weeks ago
Hi, Check that there is no…
Check that there is no firewall, etc that might block the connection. Transport endpoint is not connected is TCP/IP error and TCP/IP connection fails for some reason.
  • Thu, 06/19/2025 - 09:33
    Gurux.DLMS.Python 1.0.185
  • Wed, 06/18/2025 - 15:11
    Gurux.DLMS.Python 1.0.184
  • Wed, 06/18/2025 - 10:05
    Gurux.DLMS.Python 1.0.183
  • Wed, 06/18/2025 - 09:06
    GXDLMSDirector 9.0.2506.1801
  • Wed, 06/18/2025 - 08:41
    Gurux.DLMS.Net 9.0.2506.1801
  • HLS GMAC L+G 570
  • Unable to read parameter values from Landis+Gyr E550 meter using GXDLMSDirector - NoAccess status
  • data.SetComplete(false); But all data recieved
  • Crash (endless loop)
  • Server is not able to download object list with maxPduSize 64 or 128 (or anything below 156-bytes PDU size)
