By shagufta, 19 June, 2024 Forums DLMSDirector Can we push the code through optical port ? How to setup push without authentication? Hi, That depends on the⦠Hi, That depends on the meter and how it's configured. You need to check this from the meter documentation. There is usually a P1 serial port where push messages are sent. BR, Mikko Log in or register to post comments
Hi, That depends on theā¦
